a couple of good choices would be the Weiend Stealth, Edlebrock Performer RPm and even the plain Performer.
the Stealth by most accounts gives the best all around performance as it is has good low end and real good mid-range performance. probably where you are going to be spending 90% of your time. the Peformer RPM is probably a close second choice, while the Performer is real good low end, but gives up mid-range and top end to the other two.
rgds
Mike
