Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 05:25 PM
medic299 medic299 is offline
medic299 is starting off with a positive reputation.
2003 F150 4.6 romeo oil pressure
I have a 2003 F150 4.6 romeo with 115k that has ticking noise after warming up. It will also kick the oil light on as well. However, i can turn it off, start it back up and the light will stay off for a period of time, then trip back on. No loss of power, no increase in ticking noise, no oil in water and no water in oil. Now i have resigned myself to the fact that it is most likely ready for a rebuild. My question is what engines are interchangable or is there an on line reference to what can be put in there. Ford says that only a 4.6 romeo from 2002-2003.....from what i am reading and finding out is this wasn t the best engine on a good day. I can get a used 5.4 about 400 cheaper than a 4.6. Any help is greatly appreciated. DV
  #2 (permalink)
Old 07-03-2009, 09:17 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is online now
2005 Ford F-250
Johnny Langton has a good reputation on FTE. Johnny Langton has a good reputation on FTE.
Quote:
You've been reading wrong.
The 4.6L is a tough small V-8 that'll do alot more than it's given credit for.
At 115K miles, unless you've run it low or dry on oil, there's no reason it needs a rebuild.
JL
__________________
1997 Thunderbird LX 4.6L/4R70W
12.16@111.78
1998 F150 Supercab 4.6L/4R70W-Gone,sold to Dad.
2005 F250 Crewcab
3V V10/Torqshift 4.10LS
2001 Navigator
WANTED: OEM cat-back Exhaust from 2005-2007 5.4L or 6.8L Superduty
  #3 (permalink)
Old 07-03-2009, 09:39 AM
Seems there is very little info on the romeo engine that i can find. As far as running low on oil, not done, have followed Ford's recommended service regime very closely. Once in a while when out on road between jobs may have had 4000 miles instead of 3k between oil changes. Have always used Motorcraft filters and Castrol oil. Thanks for your insight. DV
  #4 (permalink)
Old 07-03-2009, 09:43 AM
2005 Ford F-250
Then barring a defective mechanical parts failure-that engine is in great shape. There are only minute differences in the Romeo and Windsor engines,nothing related to reliability or toughness at all. It's probably a valve lash adjuster ticking a bit, or a chain tensioner loosening up a bit at low RPM and lower oil pressures. Nothing I'd worry about unless it got progressively louder over time.
JL
__________________
12.16@111.78
2005 F250 Crewcab
2001 Navigator
  #5 (permalink)
Old 07-03-2009, 09:53 AM
Johnny,
any idea about the oil light? should i put a mechanical gauge on it? Driving me crazy! I am big ole boy riding around in toyota tacoma and i miss my space. Thanks, Darrell
  #6 (permalink)
Old 07-03-2009, 09:58 AM
2005 Ford F-250
Johnny,
It probably need a new sending unit.But,if you're concerned about it-grab a cheapie mechanical gauge,and install in temporarily(just run the oil pressure supply line up over the engine,out the back of the hood and stick the gauge on the wiper arm) just so you can see the pressure. Hot idle should be 12-25 psi,and hot cruising speed (~2K rpms) should be 40-50 psi.
JL
__________________
12.16@111.78
2005 F250 Crewcab
2001 Navigator
  #7 (permalink)
Old 07-03-2009, 10:10 AM
i'll try that this afternoon. Thanks for the insight! I'll post back what i come up with. dv
  #8 (permalink)
Old 07-10-2009, 10:16 PM
well follow up isn't pretty. I put a mechanical gauge on and on cold crank registered between 16-20 psi and no rattle. Once rpms were increased psi increased to 48-52. I let the truck sit idling until oil got warmed and lo and behold oil gauge dropped to 4 psi and it rattled like a singer sewing machine. I immediately turned it off. I now realize that i will need to replace it or rebuild it. While researching replacements i find that only 2002 and 2003 4.6 Vin W is all listed for this truck. I have my eye on a 2006 4.6 Vin W with low milage. What is the chance this will work? any help is most welcome. Thanks, Darrell
Tags
1998 , 2003 , 46 , 46l , adjuster , f150 , ford , galley , lash , oil , pressure , replacing , tensioner , ticking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
