Go Back   Ford Truck Enthusiasts Forums > General > General NON-Automotive Conversation
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General NON-Automotive Conversation No Political, Sexual or Religious topics please. SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 05:23 PM
websthes's Avatar
websthes websthes is online now
websthes has a very good reputation on FTE. websthes has a very good reputation on FTE. websthes has a very good reputation on FTE.
lawn mower starts... then dies
first thing I noticed is the primer... it seems to be sucking more air than gas... but when i peek in the carb, i can see the gas squirting in there, and after priming it like 20-30 times, the engine will start, but it dies after a few seconds.
I removed the fuel tank, then removed the fuel bowl off the bottom of the carb.. there was gas in there, the little plastic float moves just fine.
I tried blowing thru the hose that delivers the fuel to the carb but I can't. So I'm guessing there's something jammed up in the carb... am I guessing right?
  #2 (permalink)
Old 07-02-2009, 05:51 PM
hoosierbaby64's Avatar
hoosierbaby64 hoosierbaby64 is offline
Giver of Moose Smooches
1979 Chevrolet Corvette
My Garage
hoosierbaby64 has much to be proud of hoosierbaby64 has much to be proud of hoosierbaby64 has much to be proud of hoosierbaby64 has much to be proud of hoosierbaby64 has much to be proud of hoosierbaby64 has much to be proud of hoosierbaby64 has much to be proud of hoosierbaby64 has much to be proud of hoosierbaby64 has much to be proud of hoosierbaby64 has much to be proud of
Mine was kinda acting like that and it was water in the fuel. So a guests dumped some rubbing alcohol in and it stayed running. But since you cant blow thru the tube I would guess there is an issue there. I am no mechanic but I hope you get the problem solved.
You may also want to make sure you don't have diesel in it instead of gas.
__________________
Being on FTE is like peeing on yourself, everyone can see it but only you know the warm feeling that it brings!
  #3 (permalink)
Old 07-02-2009, 06:00 PM
jim henderson jim henderson is offline
jim henderson has a very good reputation on FTE. jim henderson has a very good reputation on FTE. jim henderson has a very good reputation on FTE.
If it has been sitting a long time it may have gummed up or varnished the jets in the carb.
My generator often does this if I let it sit, especially if the gas in the carb dries out.
If you are handy in the garage, most carbs are pretty easy to disassemble and clean. becareful about damaging gaskets so you can reuse them.
Usually I find that the jet and or needle valve inside the float bowl are the most likely culprits to clog up.
Carb cleaner and some fine drill bits to poke out gunk are usually all it takes.
To prevent clogging I empty the tank and run the engine til it dies.
Good Luck,
Jim Henderson.
  #4 (permalink)
Old 07-02-2009, 06:04 PM
Action4478's Avatar
Action4478 Action4478 is online now
taH ssA
Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE.
\Most likely some junk in the jets ,,may need a good cleaning ....
__________________
Rick.......
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer".... Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
  #5 (permalink)
Old 07-02-2009, 06:07 PM
websthes's Avatar
I have the carb off.. there's a big o-ring where it sends the fuel to the motor, and I took the gasket off as best I could.
Can I just soak the whole thing in some parts cleaner?
  #6 (permalink)
Old 07-03-2009, 12:08 AM
mercman86's Avatar
mercman86 mercman86 is offline
mercman86 is starting off with a positive reputation.
If you are gonna soak the entire carb in parts cleaner, make sure you remove any plastic or rubber componets off of it. They will get damaged by the solvent.
__________________
Alex
2004 F-150 XL 4.6 Triton
1966 Falcon Ranchero 200ci I6
1999 Taurus SEL 3.0 24V
2007 Viking RV Pop-UP
  #7 (permalink)
Old 07-03-2009, 01:32 AM
daddy172005's Avatar
daddy172005 daddy172005 is offline
daddy172005 is starting off with a positive reputation.
What does the air filter look like?
__________________
Mason
74 F100 302
  #8 (permalink)
Old 07-03-2009, 07:24 AM
ckal704's Avatar
ckal704 ckal704 is offline
ckal704 has a great reputation on FTE. ckal704 has a great reputation on FTE. ckal704 has a great reputation on FTE. ckal704 has a great reputation on FTE.
Likely possibilities:
1 water in fuel. Will eventually pass, but it is easier to drain the carb and fuel tank and replace with fresh gas
2 clogged fuel line. Kinda uncommon with most newer engines as they have a filter in the tank. Pull fuel line off carb. Drain some fuel. It should exit the fuel line with a stream of fuel that is the same diameter as the fuel line. If it trickles, it is blocked somewhere.
3 blockage in the float needle valve assembly. Pull the bowl. Let the float hang. Fuel should trickle steadily and somewhat rapidly.
4 blockage in the pickup tube. Careful application of a small drill bit run up through the pickup tube will clear it.
Running and stopping is a clear indication of lack of fuel. If you have to prime it that much to get it to fire, I am betting there was some water in the bowl. Or your primer bulb might have a tear. Can you see the fuel shoot up the p/u tube when you push the primer? If so, bulb is ok. Lots of fuel shooting into the carb barrel but still hard to start? Probably old fuel or has water in in.
You don't say what kind of engine, but there are tons of carb pictures etc. online.
__________________
97 250 PSD Ex Cab Sd 4X4 ZF5 135k
6637 in, 4" stainless ex
cat-less
Pyro & Boost
15.6k (tx c00n!)
Fumoto drain
HPX
Marinco block heater tap
08 Diff cover
R.P. trans fluids
203 deg t-stat
Line-X
SiriusXM music & talk
Hula HP
EBPV brake
"I tried being reasonable. I didn't like it."
  #9 (permalink)
Old 07-03-2009, 10:48 AM
websthes's Avatar
It's a sears Craftsman... think it's a briggs and stratton engine but the sticker's washed off.
I put it in a jar with some parts cleaner last night. This morning I put the fuel line back on and was able to blow some air thru so I guess I cleared out whatever was blocking it up.
Does anyone know a site with pictures of how to put this thing back together?
  #10 (permalink)
Old 07-03-2009, 10:58 AM
rangerfan's Avatar
rangerfan rangerfan is offline
rangerfan has a good reputation on FTE. rangerfan has a good reputation on FTE.
Mine did the same thing as yours did earlier in the year. I ended up putting a manual choke on it. The automatic choke was shot.
__________________
Duane
It's better to burn out... than to fade away - Joe Elliot
  #11 (permalink)
Old 07-03-2009, 06:03 PM
websthes's Avatar
Well got it back together.. have one little bolt left over but it runs good now.
  #12 (permalink)
Old 07-05-2009, 08:34 AM
guthrie&co's Avatar
guthrie&co guthrie&co is offline
guthrie&co has a good reputation on FTE. guthrie&co has a good reputation on FTE.
sometimes it is cheaper just to buy a new carb
__________________
Daniel
I come in peace. I didn't bring artillery. But I'm pleading with you, with tears in my eyes: If you screw with me, I'll kill you all." ~ Marine General James Mattis to Iraqi tribal leaders
  #13 (permalink)
Old 07-05-2009, 03:08 PM
tcbofade's Avatar
tcbofade tcbofade is offline
1986 Ford F-150
tcbofade has a brilliant future tcbofade has a brilliant future tcbofade has a brilliant future tcbofade has a brilliant future tcbofade has a brilliant future tcbofade has a brilliant future tcbofade has a brilliant future tcbofade has a brilliant future tcbofade has a brilliant future tcbofade has a brilliant future tcbofade has a brilliant future
...no job is finished unless you have some parts left over!
Glad that it's running!
__________________
Join the Missouri Chapter!
Drunks and children tell the truth. Guess which one I am?
  #14 (permalink)
Old 07-05-2009, 05:13 PM
websthes's Avatar
Getting the carb off was more trouble than anything... I used some degreaser from Canadian Tire, the guy said it doesn't damage the rubber but it cleared the gunk out of there.
  #15 (permalink)
Old 07-06-2009, 02:18 PM
Flexfuel-Dave's Avatar
Flexfuel-Dave Flexfuel-Dave is offline
Flexfuel-Dave is starting off with a positive reputation.
My mower did the same thing earlier this year. It would start then die shortly after. It's a 10-year old Craftsman 5 1/2hp mulcher.
The gas and flow was good. It turned out that my spark plug was way out of gap.
After regapping it to the magic .040", it runs like like an angry woodchuck!
Tags
briggs , carburator , craftsman , dies , drain , engine , ford , gas , lawn , mower , picture , push , ride , starts , stratton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
