Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 07-03-2009, 11:23 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Dave Sponaugle View Post
Fat fingers and not proof reading my post.
I never took typing in school either, so I am still happy I do as well as I do.
If I had any idea they would invent the personal computer and you would have to type on it, you can bet typing would have been one of my classes.
Some pretty fat fingers there Dave...
You do know I'm pulling your chain I hope!
Yes, I would have taking typing in school as well had I known the PC would be invented and that I would be in the PC biz for 20 years... I still can't type!
Though after that long I rarely make typos, yes I may misspell, but I rarely make typing errors... You don't get very far in the coding (programming) world making typos.
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #17 (permalink)
Old 07-04-2009, 01:10 AM
wreckinball's Avatar
wreckinball wreckinball is offline
1994 Ford F-350
wreckinball is starting off with a positive reputation.
yeah dave you dont need to know how to type now........ just get the voice recognition software to blow your mind!
__________________
94 F350 Extra Cab 7.3l IDI NA W/C6. Major mod is the F150 Body(LMAO) my truck makes me laugh and everyone else scratch their heads!
BC Chapter Member
  #18 (permalink)
Old 07-04-2009, 01:29 AM
Wreckingball, Have you ever tried voice recognition software?
The human voice changes throughout the day as well as atmospheric changes.
It takes a lot of practice to learn to speak in a monotone voice to get them to be accurate, I have setup many systems for the physically challenged and it takes hours and hours of "Teaching the Software" to recognize ones voice.
Yup, It's getting better, but it isn't there yet!
-Enjoy
fh : )_~
__________________
  #19 (permalink)
Old 07-04-2009, 01:45 AM
1994 Ford F-350
mine is but then again i get access to better stuff via the military.
__________________
BC Chapter Member
  #20 (permalink)
Old 07-04-2009, 12:00 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
I have one of those voices that people recognise on the phone that I have not talked to for a long time.
Sorta southern drawl type thing.
I tried some of the voice recognition software, had to teach it every word I said.
I usually just run a spell checker, but that don't catch things like breed and bread since they are both words.
Yes, I know you are pulling my chain.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #21 (permalink)
Old 07-04-2009, 01:25 PM
1994 Ford F-350
haha, well now you know! haha
__________________
BC Chapter Member
  #22 (permalink)
Old 07-05-2009, 03:35 PM
kenjh kenjh is offline
kenjh is starting off with a positive reputation.
past experiance with tired diesels and not enough money for $180.00 worth of glow plugs ment starting fluid fo the whole winter ..with new glugs in the spring the truck is fine and no ill efects...and 400,000 kilomeaters...ether like anything else in moderation works..
  #23 (permalink)
Old 07-05-2009, 04:17 PM
Hotairjunkie's Avatar
Hotairjunkie Hotairjunkie is offline
Hotairjunkie is starting off with a positive reputation.
I went through a fair amount of ether on mine in the past year, until I found this site and you guys have helped me to cure my air induction issue! So far, no ill effects that I can determine. Thanks to all who have shared their expertise!
  #24 (permalink)
Old 07-05-2009, 06:35 PM
It's Air Intrusion not Induction.
-Enjoy
fh : )_~
__________________
  #25 (permalink)
Old 07-05-2009, 07:14 PM
better induction = more air =more POWER!!! right??
  #26 (permalink)
Old 07-05-2009, 09:14 PM
David85's Avatar
David85 David85 is offline
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
As I've said before, use starting fluid only in a situation where some one's life may depend on that engine starting where it otherwise would not start on its own. But if anyone comes anywhere near my truck with that stuff, they are taking their life into their hands.
Properly maintaining the vehicle is much better insurance than driving around with a can of ether "just in case". People also need to understand that there are other alternatives to ether.
- An IDI that is plugged in will start without glow plugs even below freezing temperatures. For below 40F, you damn well better have it in perfect condition or don't drive it at all.
- A rag soaked with some gas on the intake works similar to starting fluid, but the flame speed is much lower and less likely to cause harm to the engine,
- Blowing hot air down the intake of the engine will work about as well as glow plugs. In my case I used a 1500w heat gun and the engine blew to life on all cylinders after the 3rd full turn, it was like flicking on a switch.
- Being able to troubleshoot the engine on the side of the road will also help. Simply knowing how to manually operate the glow plugs from under the hood might make the difference depending on what is or is not working properly.
A combination of #1 and #3 is more than enough to get even the most stubborn engine to run (do not point a heat gun at a fuel soaked rag!). If the engine still won't fire, then it has other issues that need to be dealt with BEFORE it could result in that hypothetical life and death situation or simply being stranded miles from home.
These engines are very reliable if you know how to work on them and understand the theory of operation for the critical systems, but if not, they might as well be a boat anchor. Remember, we don't have a warranty to fall back on with our 20+ year old trucks.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #27 (permalink)
Old 07-05-2009, 10:13 PM
dyoung14's Avatar
dyoung14 dyoung14 is offline
1986 Ford F-250
dyoung14 is starting off with a positive reputation.
right now my dads truck has every glow plug burned out i am in the process of ordering him glow plugs and putting them in for him, as of now he has to shoot either in it to get it to crank, he would plug it in but its kinda hard to plug one in when you dont have any eletricity or money to pay the electric bill, so sometimes you have to make due as best as you can with what you got
__________________
1986 ford f250 XLT Lariat 4x4 6.9 n/a, t19,285/75/16 maxxis mudders, on gun metal grey wagon wheels, soup bowl and restrictor plate gone, equis performance water temp, and oil pressure gauges, factory tach, putting a non wastegated psd turbo on it very soon, and going to run isspro boost and pyro gauges and maybe isspro tach along with factory tach just for kicks and giggles
  #28 (permalink)
Old 07-06-2009, 12:49 AM
Quote:
Yup, Can't argue that.
However, that has nothing to do with this thread!
-Enjoy
fh : )_~
__________________
  #29 (permalink)
Old 07-06-2009, 12:34 PM
redbug redbug is offline
redbug is starting off with a positive reputation.
Would rather not us it, but I must confess I have used it. The only time I need it is if I have started the engine and only let it run about 1 minute just to move the truck a few feet... Long enough to heat a sensor that tells the glow plug system its warm enough not to come on.. But, the engine is not warm enough to start... The plugs don't come on. Then, I squirt a very small amount in, as little as I can. Or, I just wait for the sensor to cool... Though, in the summer cooling can take about 20 minutes... Winter, no problems. This does not happen often. I have found that it will always start if the glow plugs are working or if the engine is warm enough. If it doesn't start, don't bother wearing out the batteries or the starter...
I can see the logic of explosions and ether... In my situation the plugs won't go back on so that's probably why I've never had a "Kaboom". Plus, I have momentary contact switch in the circuit to prevent the glow plugs from burning up which is another work-around, but also an added anti-theft device.
My 1956 Allis Chalmers Dozer came with an ether dispenser mounted on the dash... but, it also did not have glow plugs!
Only other starting issues I had were because of a clogged fuel filter.
  #30 (permalink)
Old 07-06-2009, 04:38 PM
JOEOIL JOEOIL is offline
JOEOIL is starting off with a positive reputation.
a small shot of insperation every mourning, screw that controler. 320,000 miles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
