Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 04:46 PM
Huntersbo Huntersbo is offline
Huntersbo is starting off with a positive reputation.
which heads should I get for 351w offroad truck?
For my two wheel drive '82 F-150 I will be overhauling the 351W engine. What are the best factory heads to port? I am going to be running a six pinion planetary C4 with 35" tires.
  #2 (permalink)
Old 07-02-2009, 05:27 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
For the money you're gonna spend on porting and valves you could have some Dart iron eagles that outflow any stock head ported right out to the water jackets. Some of the AFR and TFS aluminum heads are similarly priced, and even a pair of World Windsor Sr heads woul give you a hugh upgrade over stock.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, 1.6 RR, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, and now power steering!!
  #3 (permalink)
Old 07-07-2009, 07:53 PM
fordeverpower's Avatar
fordeverpower fordeverpower is offline
fordeverpower is starting off with a positive reputation.
RHS is the best value!
__________________
Matt
78 F100 390 2wd c6
79 F150 351m 4x4 c6
79 f150 390 rip
Avatar is Barry Rabotnick's emc motor!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
