Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 03:49 PM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
Lightbulb Air Conditioning Mods - Consolidated Reference Materials
I had some extra time today, so I read through the A/C mod threads in plans of doing them to ym own truck very soon. There is a lot of excellent information. However, for someone who wants to do the mod, reading through all the numerous posts can be very daunting and can sometimes be discouraging for someone who simply wants to just know how to do it.
Therefore, after pouring through the threads and links on the A/C mods (both the Heater Valve Mod and the Compressor Shim Mod), I've done the following:
- created screen shots from critically informative posts,
- organized the information into a logical flow,
- filtered out the "I did it too..." type of comments,
- added a few simplified summary comments here and there,
- I went through my shop manual and included diagrams of the Vacuum System, and THEN
- compiled all the condensed info into a couple of PDF files which are attached below.
I tried to trace the info back to original sources as much as I could to give credit where credit is due. Just to make sure that anyone who gets the PDF file can see ALL the info in the original threads, I also included links to the threads from which I took snapshot images of posts.
Personally, I think the documents below are simpler to follow because they don't include the non-instructive or repetitive comments. I filtered those comments out not because they aren't important, don't have value, or for any other reason other than to just create a document that is "Just the facts, ma'am... just the facts."
I would like to do the same with other Mod/Repair threads that are linked in the RHN site (or the old 7point3.com site), but this is obviously a very time consuming effort and I'll just sort of do them as I can find the time to do so.
I would appreciate your input to see if I'm on the right track here, and especially if you folks think it's worth the time and effort for someone other than myself.
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
  #2 (permalink)
Old 07-02-2009, 04:24 PM
mueckster's Avatar
mueckster mueckster is offline
Redneck Wrencher
mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold
Good job, Pete. This is the time of the year when these questions frequently pop up. Thanks for your efforts. Keep up the good work.
__________________
-Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner F6, AFE II w/ Pete's Cover, Garrett GTP38R w/ 1.15, 6.0 IC, Casserly SS 160cc 100% over, Stealth HPOP, Autometer Phantom gauges, DIY HD 4R100, 4" MBRP, Procomp lift pump, CCK, TruCool, billet 710 cap, Truetrac rear (soon)
PAA Member #62
  #3 (permalink)
Old 07-02-2009, 04:52 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is offline
Caution! Will Blow Smoke.
Bigcat350 is gaining momentum as a positive member of FTE. Bigcat350 is gaining momentum as a positive member of FTE.
Great job Pete. I wish you had done this last week. I just went thru all of the treads about these mods.It took longer looking and reading than it did to actually do the mods.
__________________
Eddie Late 01/99 F-350 XLT 7.3 EC DRW 4x4 6-speed 4:10, some common mods done. 6637 filter & Pete's Cover, Billet Grill,Muffler Delete,Stancore GPR,2 Pillar Pod Gauges,Swamps Hybrid Single Shot Injectors,DP Tuner NS,Modified Stock,Hi-Idle,80E,120R,140A,Foil Delete,CCV,AIH Delete,Garrett GTP38R BB Turbo with a 1.15 Housing, Valair Ceramic/Kevlar Clutch. And more. Over 400HP BIG RED TRUCK - PAA#79
  #4 (permalink)
Old 07-02-2009, 05:42 PM
mxdadof2's Avatar
mxdadof2 mxdadof2 is offline
mxdadof2 is gaining momentum as a positive member of FTE.
Great Idea Pete and thanks for taking the time, maybe one of the MODS can make it a sticky or something where it will be easy to access. Where one doesnt have to search for this post as well.....
__________________
Ron- 01' 7.3 PSD EC 4x4 no mods yet... but working on those.....
PAA Member #80
Mississippi Chapter Member
  #5 (permalink)
Old 07-02-2009, 05:54 PM
KelVarnson KelVarnson is offline
KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE.
Awesome!! Printed out for reference in the very near future. I hereby rep thee...
__________________
'02 F250 SCLB 7.3 4WD, 105k. 6637 Filter, JW Valve Body, 6.0 Trans Cooler, 285/75 16 Michelin LTX-AT2's, Line-X, Snug-Top Shell, Yakima Racks.
  #6 (permalink)
Old 07-02-2009, 05:56 PM
F250_'s Avatar
2002 Ford F-250
Thanks guys. I have several of these PDF document accumulating that I need to send to either Neal or Guzzle so we can get them up on that site for easy and quick access.
__________________
  #7 (permalink)
Old 07-02-2009, 07:14 PM
00Dave's Avatar
00Dave 00Dave is offline
00Dave is gaining momentum as a positive member of FTE.
Way to go Pete!! If I ever meet you I will bow in the presence of your awesomeness. I tried to rep but got to spread it around
__________________
David, 2000 F-250 CC 4x4, 6637 w/Pete's cover, Zoodad, Bilsteins, Walker BTM, dipricol gauges, dp-tuner F5 w/ 40T, 60T, 80E, King Ranch seats
In Remembrance of JET, Give without remembering Receive without forgettin
Mark, thank you, see you on the other side!
  #8 (permalink)
Old 07-02-2009, 07:52 PM
MJScore's Avatar
MJScore MJScore is offline
MJScore is starting off with a positive reputation.
Great job, I just bought the parts to do this but looking behind the glove box I don't see a red hose. Does anyone have a picture of the location of the red hose to tee off of? Thanks.
  #9 (permalink)
Old 07-02-2009, 08:08 PM
F350-6's Avatar
F350-6 F350-6 is offline
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Nice work making this short and sweet, Pete. I need to do this to my wife's truck. Maybe this weekend. I'd rep ya, but I gotta spread it around first.
If no one has a picture, I'll see if I can take one when I tear into this MJ.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #10 (permalink)
Old 07-02-2009, 08:14 PM
87 F-150 I6's Avatar
87 F-150 I6 87 F-150 I6 is offline
Duct tape and a hammer!
87 F-150 I6 has a good reputation on FTE. 87 F-150 I6 has a good reputation on FTE.
Great job with the write up.
__________________
Andrew
2002 F-250 7.3L 4X4 CC SB AT /6637 mod/SS HPX/Stancore GPR/5" MBRP exhaust/Foil Delete/
  #11 (permalink)
Old 07-02-2009, 10:37 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future
Outstanding Pete Thanks for soing this. Reps sent to you.
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back Into 6" Stacks, 6637 w/,Custom Cold Air Intake ,Autometer guages, DP TUNER
http://www.roadsidehelpnetwork.info/
PAA # 14
RIP Mark.. I'll never forget you!!
  #12 (permalink)
Old 07-03-2009, 12:47 AM
N V US Lawn Care's Avatar
N V US Lawn Care N V US Lawn Care is offline
1999 Ford F-Super Duty
N V US Lawn Care is starting off with a positive reputation.
Pete, simply, three words...You the Man...i was already planning on doing these mods and was a little confused and started letting my lack of confidence in my ability to do it right stop me from buying the parts today, but, as always, you, and every other FTE guru have got my back
Timeline: I was gonna buy the parts at 6 pm today, chickened out...hehehe
11:45 pm, same night, Pete posts this, absolutely astonishing thread that
explains it all...
9 am tomorrow, my butt will be getting these parts and doing this mod.
Thanks a bunch Pete. I got no reps to give just yet, but you're in my thoughts brother.
Last edited by megawatt00; 07-03-2009 at 08:07 AM. Reason: remove inappropriate language
  #13 (permalink)
Old 07-03-2009, 12:58 AM
F250_'s Avatar
2002 Ford F-250
You guys are too kind. I'm really glad that it seems to be a help, though. Even though I can't always offer unique or new insights, I can use what little I DO know to organize information so that it's easier to sort through.
__________________
  #14 (permalink)
Old 07-03-2009, 01:02 AM
Pete, I just noticed that you're in Bama too, when you heading up to the RR Event? Maybe we could choo-choo from Huntsville...you know the last 262 miles...let me know
  #15 (permalink)
Old 07-03-2009, 01:06 AM
F250_'s Avatar
2002 Ford F-250
I looked at our two routes, and they don't actually meet up with each other until Chattanooga, TN. I'm planning on leaving from work on Thursday evening and arriving late Thursday night. Then I'll also be coming back Saturday in time to be back in B'ham by about 5-6pm. My 23rd anniversary is that Sunday, so I HAVE to be home before late Saturday.
When are you headed up?
__________________
Tags
2000 , 2001 , 350 , 73 , 99 , ac , air , compressor , conditioning , diesel , f350 , filter , ford , location , mod , shut , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
