Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-03-2009, 10:25 AM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
2004 Ford F-250
1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE.
Nice work! Those are great! I'm about to do the cold AC mod so timing was perfect. Reps to you!
  #17 (permalink)
Old 07-03-2009, 08:15 PM
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold
The problem I have is that the compressor is at .025 clearence with the A/C clutch. The compressor runs all the time. Does not switch off and on like it's suppose to. It does shut off when you turn the A/C off, but other than that, it runs all the time. I added some freon, and then it started to shut off and on constantly. It was up to around 60 lbs of pressure. I released some freon and that stopped. The coldest I can get it to blow is 60 degrees. Compressor runs all the time. Any ideas? I have installed the shut-off valve on the heater hose which did help some, but that obviously doesn't address the compressor problem.
__________________
1997 Super Duty, PSD,6637, high idle, 50hp, & 80hp. 150cc injectors.
2002 F250 Crew Cab, 8' bed, 4X4, PSD, 6637, 4" magnaflow exhaust, high idle, 50, 75 tow, 100, 120, & 140, HPX Crossover
Kentucky Chapter Member
  #18 (permalink)
Old 07-05-2009, 12:44 AM
N V US Lawn Care's Avatar
N V US Lawn Care N V US Lawn Care is offline
1999 Ford F-Super Duty
N V US Lawn Care is starting off with a positive reputation.
Git my stuff.....
Guys, I bought all the stuff listed as "gotta haves" for this mod yesterday...i haven't got it done yet, but, i only paid $24 for all this...the receipt is in the center...whoo hoo
  #19 (permalink)
Old 07-05-2009, 08:30 PM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
John:
I don't ave a clue about the continually running compressor issue. Might be worth starting a thread just for that... might get more attention from others who are more knowledgeable.
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
  #20 (permalink)
Old 07-05-2009, 08:56 PM
beanhead6D5's Avatar
beanhead6D5 beanhead6D5 is offline
of Family
beanhead6D5 has a very good reputation on FTE. beanhead6D5 has a very good reputation on FTE. beanhead6D5 has a very good reputation on FTE. beanhead6D5 has a very good reputation on FTE.
Somebody rep Pete for me!
Well done Pete,well done!
__________________
Brad
PAA MEMBER #71
2001 f-250 CC 4x4 auto 7.3,S&B intake,WW,1.00, 4"turbo bk,HPX,intank mods,
Isspro gauges,cold a/c,OBA,ccv,6.0 IC TC,AIH and EBPV delete,DP turner
1965 F-100 2wd,390,4spd.
  #21 (permalink)
Old 07-06-2009, 10:21 AM
Pete, i was planning on rolling out of H-ville Thurs. evening too...if I can go at all...are you not rolling up I-65 to 72 here in H-ville?? Or did you find a "shorter route? Anything that saves me the OPEC profits would be a plus...hehehe.
  #22 (permalink)
Old 07-06-2009, 12:45 PM
F250_'s Avatar
2002 Ford F-250
David:
If I go up through Huntsville, it adds 60 miles to the trip, and I have to pinch my fuel pennies and really want toa void an extra hour's driving, too. I'll be taking 59 North out of Birmingham all the way to Chattanooga. From there, you and I both have the same route... I-24E, I-75N, and then I-40E.
Run the maps on Google and you'll see what I'm talking about.
Also, I'm actually going to try to get out of B'ham by 4PM so I can get in "not too late" and get the key to the cabin before everyone goes to bed.
__________________
  #23 (permalink)
Old 07-06-2009, 12:47 PM
DieselBeast01's Avatar
DieselBeast01 DieselBeast01 is offline
2001 Ford F-250
DieselBeast01 is gaining momentum as a positive member of FTE.
I have been waiting for someone to do this for a long time. Great job.
__________________
Clint
'01 F250 XLT 7.3L PSD SC Short Bed 4x4--DP Tuner (w/ NS, Stock, 80 econ, 60 tow, 80 tow, 140 extreme), ITP Overboost Annihilator, 6637 with Pete's Cover, Zoodad mod, 5" MKO Exhaust, foil delete, CCV mod, IDM mod, 2008 Center Console, gauges, 3.5" Rough Country leveling Kit on 35x12.50 Nitto Mud Grapplers.
'91 BMW 525i 5-speed--31MPG
  #24 (permalink)
Old 07-06-2009, 12:49 PM
yeah, that's right Pete, you're cabining it ...I'll just be sleeping where i park...THAT'S HOW I ROLL....hehehehe....
  #25 (permalink)
Old 07-06-2009, 01:02 PM
MJScore's Avatar
MJScore MJScore is offline
MJScore is starting off with a positive reputation.
Well I did the A/C heater mod this weekend and it made a good difference in how the cooling is working in the truck. Now to save up for some gauges.
  #26 (permalink)
Old 07-06-2009, 11:22 PM
2004 Ford F-250
Quote:
Well.... I tried to do the cold AC mod. I bought the kit from dieselsite and was about to install it and found that my hose has a valve in it already. After talking with Bob at dieselsite he said that I probably already had the equivalent of this mod. So, I did a quick check and, sure enough, that valve is in one position for all settings except MAX AC. In MAX AC, it moves to the other position.
Thankfully, Bob was kind enough to accept a return on this so I'll be sending it back. Unless someone on here could use. PM me for details Brand new, never used.
So in short, it looks like the gassers might already have the equivalent of this in place. Here's the valve I'm talking about.....
Last edited by megawatt00; 07-07-2009 at 04:31 PM. Reason: Items for sale not permitted in forums.
  #27 (permalink)
Old 07-07-2009, 08:45 AM
F250_'s Avatar
2002 Ford F-250
Good input, Jason. I'm glad that Bob is taking care of you on this. I'm getting ready to do this myself and will try to take a few more pics of the entire install process and then I'll update my PDF file and repost the updated version.
__________________
  #28 (permalink)
Old 07-07-2009, 09:06 AM
harry whooo harry whooo is offline
harry whooo is starting off with a positive reputation.
Quote:
Yes, what he said. Mine does the same thing?
  #29 (permalink)
Old 07-07-2009, 10:38 AM
RedBoat's Avatar
RedBoat RedBoat is offline
Rather Be Floatin
RedBoat has a very good reputation on FTE. RedBoat has a very good reputation on FTE. RedBoat has a very good reputation on FTE.
Reps to ya Pete!!
Somebody rep him for me I'm in time out again!!
__________________
Costa
2003, F-250, 7.3L, 2wd, Auto, 4 Door, Lariat, Short Box, DP-Tuner, Isspro Pyro, Boost, and Tranny Temp, 6637 with Petes cover, Fumoto, Bilsteins,
2" Leveling Kit, Hutch/Harpoon, Foil Delete Mod, Upgraded boots, CCV Mod, Ac Improvement Mod, Michelin LT285/75R/16 LTX AT2's
  #30 (permalink)
Old 07-07-2009, 03:01 PM
DieselCamper01's Avatar
DieselCamper01 DieselCamper01 is offline
2001 Ford F-350
DieselCamper01 has a great reputation on FTE. DieselCamper01 has a great reputation on FTE. DieselCamper01 has a great reputation on FTE. DieselCamper01 has a great reputation on FTE. DieselCamper01 has a great reputation on FTE.
I sent him some reps for ya guys
__________________
Jay
2001 F350 Lariat CC LB 4X4, MagHytech, 6637, CCV, Hutch & filter, DiPricol gauges, EBPV & foil delete, Cryo Powerslots, Hawk pads, LED, Bilsteins, IDM, Fumoto, MBRP 4", PAA#82, DP Tuner (Outrageous!), Petes Cover, WW
http://www.roadsidehelpnetwork.info/
Tags
2000 , 2001 , 350 , 73 , 99 , ac , air , compressor , conditioning , diesel , f350 , filter , ford , location , mod , shut , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
