Go Back   Ford Truck Enthusiasts Forums > Misc. > Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 03:39 PM
blakec blakec is offline
blakec is starting off with a positive reputation.
Where am I going to put all this stuff?
I have recently purchased new stereo equipment. I have a 2 dinn Pioneer DVD head unit and will be adding the XM radio module, 6 disc changer, Blue Tooth module, & HD Radio module. Also, I want to put in my 4 channel amp to run the front & rear speakers as well as add another 2 channel amp for a sub. So, given all of this stuff, where the heck am I going to put it all? Any placement suggestions? Also, if anyone has suggestions for where the best places are to run wiring that would be great too. Thanks.
2005 F-250 Crew Cab
6.0 PSD Automatic 4x4
  #2 (permalink)
Old 07-02-2009, 05:18 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
There is a nice little shelf under the glove box. I used to have a sat tuner in there, there should also be a lot of space under the radio (in the panel with the hook).
My next revision will include putting my processor in the space under the glove body. An amp under the radio. Then sub and sub amp still behind the back seat.
With all of this work, I would also add a layer of sound deadener to the floor, which would mean pulling the seats and carpet. This will give you plenty of space to run wires away from all others. If you don't want to go through that much trouble, the wires can be tucked under the door sills. If you plan on running 4ga or bigger down the sills, you will need to trim the spacers on the bottom of the sills.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #3 (permalink)
Old 07-02-2009, 05:42 PM
Thanks ReAX. I don't have the additional module boxes yet, so I don't know how big for small they are, so some of your suggestions could work. I think I can get my changer under the seat in the front, I have the 40/20/40. Also, looking at your mods list, looks like you have installed some subs, where did you install those? Do you have some pics? For the amp I was thinking under the rear seat, although I think my rear seat system is different than yours. I can't remember what year they changed it. In mine, you fold up the rear seat and then fold out the metal "shelf". I'm going to look into removing the metal self system. If I can get that out, I will have plenty of room for my amps. For the 4ga wire, I was thinking of running that down the frame rail and punching trough the cab where the amp will be installed.
  #4 (permalink)
Old 07-02-2009, 06:04 PM
ReAX's Avatar
2002 Ford F-250
I put two 10s behind the rear seat and built a box with the same profile as the sub box to house the electronics.
My seat back flips forward. The bottom is stationary. I believe they changed it with the body style (headlight) change.
__________________
  #5 (permalink)
Old 07-02-2009, 08:56 PM
bnovak bnovak is offline
bnovak is starting off with a positive reputation.
Deleted by poster
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
