Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 03:30 PM
Justin2233 Justin2233 is offline
Justin2233 is starting off with a positive reputation.
400M to 460
what would i have to do to swap my 400 with a 460 i have a 4 speed granny gear np205 T-Case, dana 44 and 9in rear. The 460 was a truck motor it didn't come outta a car.
  #2 (permalink)
Old 07-05-2009, 10:49 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
I suggest a search as this has been covered a bunch. basicly a set of L&L frame perches and motor mounts should be all that necessary if the 460 is complete from oil pan to intake. install a new hi quality clutch while your doing this swap it will save you big time down the road.
__________________
94 XLT 5.8/E4OD/Warn HS9500I
6"ProComp Stage II 35x12.5x15 BFG MT's
4.88 gears/Aussie Front/rear open
JBA shorty, Custom Y pipe,3" exhaust
http://www.supermotors.org/registry/...il.php?id=4158
  #3 (permalink)
Old 07-09-2009, 10:31 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
The towers are the same. Trans Dapt & Performance Unlimited Are 2 other motor mount mfgrs. If one of my L&L's ever break I'm going to try the Trans Dapt next. I wasn't too happy with the L&Ls. You should have a rear sump pan if the engine came from a 4x4.
__________________
'79 F250 13" lift 42" Super Swampers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
