Quote:
Originally Posted by Homemade
Ya mine are power locks and wiondows also how much trouble is it to use on the manual door.
You just have to open up the manual window crank hole for the power window switch and you'd have to cut square holes out for the power locks.
I don't think it would be too hard. Just take your time and use a Rotozip or something like that to cut the plastic.
Also IMO if you are going to paint the door panels to match, I would recommend using the same color panel as a base. If and when you do scratch the paint off, if the base color is the same you don't see the scratch as bad. If you use a different color as a base (such as black) every time it gets scratched the black color will show though.
SEM has some really good paint that will hold up really well. It's not cheap, but cheaper than replacement door panels.
Just my $.02
