Hey need someones help here with this problem im having.. hopefully from someone that does them for a living... Granted its not a ford... but it is old and everyone had a disc drum setup at some point... brakes are brakes imo...
trucks an 87... problem im having is only 1 wheel is locking up... will barely have any pressure on the pedal and the passenger side wheel will just lock up like youve got full force pressure on the pedal.. it also doesnt happen every single time.. some days itll do it once and then not again for the rest of the time im in it.. or itll be fine then start and keep doing it... and other times it wont do it at all... had this same problem on another vehicle i owned but never figured out what the cause of it was on that one either...
shoes are fairly new.. replaced the wheel cylinders at the same time cuz the old one leaked (which was why the shoes were changed too).. problem was there even with the old wheel cylinders.. only one line going to the back and splits in a T-fitting at the rear end to both sides...
ive run out of ideas of where to look here..
__________________
Shawn
The Republic was not established by cowards; and cowards will not preserve it ... This will remain the land of the free only so long as it is the home of the brave. Elmer Davis
Assuming the shoes are correctly installed and assuming there are no fluid leaks from wheel cylinders (which you have replaced) or from axle seals then my thoughts would be weak shoe return springs, wheel bearing play or distorted brake drum.
shoes are on correctly.. no leaks.. axel seals were replaced month after the wheel cyls twice (replaced both at the same time and got a bad new one so had to do it a 2nd time)
could be the springs.. prolly still the originals.. so ill look into those...
wouldnt the bearings and drum cause it every time? or could they do it intermittenly too?
__________________
Shawn
Except if you have a Chevy with ABS. What do you have a S-10 or S-10 Blazer?
no abs and pickup... small cab and short bed...
Quote:
Originally Posted by Ryan50hrl
Did you ever get gear lube or brake fluid on those shoes??? cause if you did they need to be replaced
not on the ones that are on there... when id changed the wheel cylinder they were saturated in the brake fluid from when the old one leaked... then the new ones again when the first axle seal leaked... i caught the 2nd time the new seal leaked before it got to the shoes... found that out when id pulled the drum off couple days later to re-adjust the star wheel.. i ended up nicking one of the seals when i put the shafts back in and thats what cause the new seal to leak.. and itd leaked on the opposite side than the first one which was mainly how i caught that one too... new shoes were bone dry still...
__________________
Shawn
got the drum hardware kit today... but was getting late by time i got it so i wont be able to get it on till tomorrow... that is if its not being story like theyre "predicting"... ill let ya know how it turns out though... might be back again asking for more help...
__________________
Shawn
welp just to update yall... ive been driving around now for 2 months since i got that hardware kit and hasnt done it since... Thanks Lazy K... really wasnt sure that would have solved it when id done it on another vehicle i had before the truck and it kept doing it... but this time it seems to have fixed the issue...
__________________
Shawn
Pulled the drums, no obvious leaks, everything COVERED in brake dust like they had been dragging.
Put new pads on the front, cleaned all of the rear components with Brakleen, scuffed and de-glazed the pads and insides of the drums with a wire wheel.
Put it all back together and they worked GREAT.
For a coupla hours.
Washed the truck, went for a ride and they're locking up again.
No fluid inside the drums or on the shoes, no obvious leaks from the wheel cyls. Pads have +/- 1/4" of friction material remaining.
What do you guys think?
Should I just "bite the bullet" and install the shoes/wheel cyls/spring kit I have on the bench?
Could be a bad rear flexi brake pipe not allowing fluid to return. Could also be a bad RABS valve module.
I think, if it was me, I would replace the rear flexi hose and if that did no good I would use a short length of brake pipe to bypass the RABS module.
