Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 01:46 PM
hop hop is offline
hop is starting off with a positive reputation.
Replacing lower ball joint
In replacing the lower control arm ball joint, is it necessary to remove the tie rod end and torsion bar?
2000xlt 5.0 2wheel 158kmi
  #2 (permalink)
Old 07-06-2009, 01:28 AM
geo455 geo455 is offline
geo455 is starting off with a positive reputation.
You do not need to remove the torsion bar since I assume you are not replacing the entire arm, even though some manuals say the ball joint is not serviceable. You need to pop off the tie rod end as well as the upper ball joint to remove the steering knuckle. Once that is out of the way just remove the split ring from the top of the lower ball joint and it's ready to be pressed out. Do a search in this forum for ball joint replacement. There is a good article on how to press the new one in with a floor jack. Good luck!
Tags
1999 , 2003 , arms , ball , control , explorer , f150 , f250 , ford , joint , joints , lower , replacing , trucks , upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
