Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 12:33 PM
gfwalsh gfwalsh is offline
gfwalsh is starting off with a positive reputation.
Explorer Stalls
4.0L won't idle. Have to keep revs up to keep it running. Garage has ruled out Catalytic converter, bad gas, fuel pressure but it still won't idle. Codes say multiple cyclinder misfire.
Any ideas?
  #2 (permalink)
Old 07-03-2009, 10:55 PM
ramontr ramontr is offline
ramontr is starting off with a positive reputation.
clean the IAC with some carb cleaner is most likely sticking it has happens or all the fords i know, cleaning is a temp. fix but it will let you know it when it works
  #3 (permalink)
Old 07-04-2009, 06:54 PM
shorod's Avatar
shorod shorod is offline
shorod is starting off with a positive reputation.
Do the codes show misfires on multiple cylinders, or does it have a single "random misfire" code of P0300? Generally, it's helpful to provide the specific code number rather than someone's interpretation of the code. Also, what year is your Explorer? The P0300 format is only valid if the Explorer is newer than a 1996.
-Rod
  #4 (permalink)
Old 07-05-2009, 07:23 PM
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
Check the vacuum lines at the vacuum tree by the firewall drivers side. What year is it?
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
  #5 (permalink)
Old 07-08-2009, 09:35 PM
Just got the vehicle (2003 Explorer) back from garage. What they found was a hole melted into the intake manifold near what they tell me is a return tube from the EGR? The manifold was then replaced and the vehicle runs OK but still starved for power. Can cruise along at 60mph but loses steam on grades and no response other than high RPMs when I kick it down. The garage did say that they noted a high temperature at one of the catalytic converters indicating a restriction.
Next stop is the Ford dealer to get a definitive on this. I'm hopeful that the emissions warranty will kick in.
  #6 (permalink)
Old 07-19-2009, 07:37 PM
snipinu snipinu is offline
snipinu is starting off with a positive reputation.
1996 Ford Explorer V6 4.0L doing something similar, has me stumped. Truck sometimes gives me trouble starting and when it starts runs rough. When I press the accelerator to the floor the truck bogs down. The truck doesnt want to accererate it has no power until it kicks into 2nd gear but you can still feel the shudder of the engine. I ran to Auto Zone and had them run a code came back single cynlider miss fire #1. Doesnt do this all the time. The Check engine light came on and I reset it hoping that I could recal the fuel system. Engine sounds like it is either getting too much air or not enough gas?
Any help out there?
  #7 (permalink)
Old 07-19-2009, 08:23 PM
shorod's Avatar
Sounds like a misfire, and the code would suggest the misfire is cylinder #1. When is the last time the Explorer had a tune up consisting of filters, spark plugs, and spark plug wires? It could also be a coil or fuel injector, but if it's been awhile since the last tune up, or at least since the plug wires were changed, then they are likely due to be replaced anyway and may just fix your misfire.
-Rod
  #8 (permalink)
Old 07-20-2009, 11:27 AM
bass3006's Avatar
bass3006 bass3006 is offline
bass3006 is starting off with a positive reputation.
happened to me one time, would run smooth as long as i held the gas but would stall out without being on the pedal. Long story short it was towed to the dealership and they replace the Mass Air Flow Sensor and it has been fine since.
Just my experience, good luck
  #9 (permalink)
Old 07-20-2009, 05:17 PM
Thanks Plannning on doing tune up very soon, I may replace the fuel filter and the plugs and wires hopefully that will fix I may change the MAF also. Once agin thanks for the assist. Has anyone ever heard of a MAP Sensor, Its in CHiltons but doesnt give information on replacement.
  #10 (permalink)
Old 07-21-2009, 12:00 AM
shorod's Avatar
The MAP sensor stands for Manifold Absolute Pressure, but I believe instead of a MAP your 2003 will have a Mass Air Flow (MAF) sensor. It will be located between the air filter and the throttle plate.
I'm not sure on the V6, but your 2003 may have Coil on Plug so you won't need to change out the spark plug wires.
-Rod
  #11 (permalink)
Old 07-21-2009, 10:19 PM
Thanks for the info!
  #12 (permalink)
Old 08-08-2009, 11:28 AM
Case Closed - Almost
Well finally the garage found it - a two part problem. A catalytic converter issue was suspected so they dropped the exhaust but it still would not idle. Source was found to be a hole burned into the intake manifold (how did that happen - hmmm?). Manifold replaced and codes cleared. They returned the vehicle to me but it still had nowhere near the power it should - 60mph max on flat ground!! Catalytic converter found to be indeed the trouble. Replaced under the 8yr/130,000km emissions warranty (would have been $3,250.00 CAD otherwise yikes!). Now I have to convince Ford that the manifold burn was caused by hot exhaust from the blocked converter hoping they honor those initial repairs as well. Fingers crossed.
Tags
explorere , ford , stalls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
