Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 10:29 AM
jmm jmm is offline
jmm is starting off with a positive reputation.
np205 speedometer worm gear
I have a 77 f250 with a divoriced np205 tranfer case. I am in need of this plastic worm gear in which the speedometer cable end drives from. I not talking about the gear on the end of the cable. My worm gear is all stripped. Does anybody know where you can get one from? i do have a spare case but i havent gotten to taking that one apart yet.
thanks
  #2 (permalink)
Old 07-02-2009, 10:47 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
It's called the Speedometer Drive Gear, The one on the end of the cable is called the driven gear.
They are available from Ford and other places.
You'll need to know the tooth count.
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #3 (permalink)
Old 07-02-2009, 12:19 PM
jmm jmm is offline
How do you know the tooth count? Mine is all stripped. What other places can you get them from?
  #4 (permalink)
Old 07-02-2009, 01:30 PM
There are several ways, 1. It highly unlikely it's stripped smooth enough to not be able to count the teeth, There will be remains, 2. You can re-calculate it very easy, 3. If you goto Ford and provide them with a little info about the truck they'll tell you what you need! As I'm sure any reputable parts house will.
Don't know, wouldn't buy it from anyone except Ford, just bought one for a BW1345 from Ford cost a whooping 25 bux + the gov for the Drive gear, 3 bux + the gov for the driven!
I suggest replacing them both at the same time, Drive and Driven.
-Enjoy
fh : )_~
__________________
Tags
19 , 205 , cable , cavle , driven , gear , gears , np , np205 , ometer , spedo , speed , speedo , speedometer , stripped , tooth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
