My Question is if your experiencing it is that hurting our engine's or turbo's
etc.
Dealer has part on order for me won't see til next week but want to drive to Maine of coarse in the rain. go for it or I'm I hurting anything,
I could really man up and take the bike
I see in your sign. that your truck is a job#1 which means that you've been driving in the rain for a while now. I don't know if it really hurts anything, but I really doubt that 1 more time will matter. I just had mine done. I drove in a little rain since then (not much though), and so far, so good.
__________________
Job #1 F-350 SRW, 6.4 PSD, Auto, 4x4, supercab, long bed, Line-X, Vent visors, AFE cold air intake, MBRP "cool duals" exhaust, Bed locker electric retractable tonneau cover, Kenwood DNX-1820 Nav./ stereo w/ backup camera, Spartan 210 hp DOC/DPF delete tune.
Yea, she not a daily driver. I've had this truck since last October and never experienced the highway issue until the last month here with this lousy
weather.
The problem fits the tsb perfectly just never experienced it till recently.
So then I'm not sure if it actually does any damage to anything either.
I would imagine that would be a tough debate....
Screw it I'll just drive it
For what it's worth my truck has been doing the sputter and smoke dance for two years. I do lots of highway driving with trailers in tow and when the rain was out, I pushed the motor just as hard as usual. There have been many times when I actually pushed the motor harder making the condition really bad so that I could make something either break or throw a code. While it has been under warranty I have really tried to make as much stuff break as possible and nothing has. My engine is running strong and I have the new CAC and it's great. I think the engine runs even better with it.
__________________
'08 F-250 4X4 CC 6.4
RideRite Airbags in Rear w/onboard compressor
Bilstein Shocks, Dual Air Horns (under hood)
Edge Insight Gauge Cluster
4-Way "wig wag" strobe lights
Polk speakers, Kicker 10" sub, 600w amp
I am now on the final leg from central Ca. through Nevada, Idaho, Wyoming, Montana, Washington and now in Oregon. I am pulling a fiver and have noticed much better performance with the new CAC.
In tow/haul it seems to pull much better with higher boost and less down shifting. Hand calculated fuel mileage has increased 1 mpg. Not sure if that is the result of the CAC or the engine getting broken in.
Cools the air coming out of your hot turbos before it goes into the engine. Since cooler air is more dense it increases the amount of air that goes into each cylinder, which increases the amount of power the engine can make, as well as lowering EGTs.
You don't need one because you already have one.
__________________
Tom,
Current truck - 2008 F250 CC 4x4 PSD
Previous Fords:
2007 F150 Screw 4x4
2003 F150 4x4 r/c auto
I had the same issue with my job 2 '08 and just had it replaced last week. Been raining a bunch here in the northeast this summer, so it was a noticable issue. I'm still not certain why/how the engine was creating the smoke? Was the original CAC sucking in the water and blowing it through the engine? OR were the fins on the original part two small/close and not allowing the CAC to cool the air down enough before pumping it back in the engine creating the smoking condition?
Either way, now I have a shiny black new CAC which should make the truck run better.
__________________
'08 F250 6.4 CC FX4
3.73 LSD, Access Bed Cover
From what i've been told the old design allowed condensation to develope on the inside of the cooler. This would slowly build up and after 20 min or so on the hwy if you jumped on the throttle or going up big hill with load then the high boost pressures would force all the moisture into your motor. Not sure how the new one resolves this but it seems to have somewhat more wider fin openings and has a much heavier / slick looking paint job.
__________________
01 Supercrew 4x4, 5.4 eng, 160K Awesome Truck
08 Dark Stone F250, 6.4, 3.73, 4x4 Lariat, Job3
ATS Color Matched Street Flares
Eaton Elocker "front" / Truetrac Limited Slip "rear"
Banks Ram Air Intake
Spartanized 75, 150, 210HP
