Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 08:47 AM
99Exp 99Exp is offline
99Exp is starting off with a positive reputation.
A/C problem
My A/C quit blowing cold so my hubby checked and it was low on coolant. He recharged the system and when we turned it on it would make a noise off and on in the back like a rush of air. 3 days later it quit blowing cold again. He checked and it needed more coolant . He put in more coolant this time with leak sealer and the same thing happened again. Any ideas? I don't want to spend a lot of money on the thing right now since times are tight for us.
It is an 03 Eddie Bauer with 68K on it.
__________________
2003 EB Expedition 5.4L 4x4
1995 Mustang GT 5.0L
Rest In Peace
1999 Expedition XLT 5.4L 4x4
  #2 (permalink)
Old 07-02-2009, 06:56 PM
alloro alloro is offline
alloro is gaining momentum as a positive member of FTE. alloro is gaining momentum as a positive member of FTE.
If you keep losing refrigerant then you have a leak. You will keep losing it until the leak is repaired. So step one is to find the leak, then fix it. There's no getting around that.
__________________
If you like the advice you get, be sure and click the left red "Add to Reputation" button
to the right of the word "permalink" at the top right of the poster's message window.
  #3 (permalink)
Old 07-02-2009, 09:34 PM
bnovak bnovak is offline
bnovak is starting off with a positive reputation.
yeah, what he said up there!
Autozone sells leak detection kits that range from $30 to $50. You get a UV dye, lightsource, and glasses that help see where it's leaking from.
until you really pinpoint the leak, you are throwing away $25 a shot on recharge kits.
If you still have one of the cannisters from the last recharge kit you used, here's a cheaper test procedure.
Cut the hose from the can to the fitting that plugs into the AC system, and attach it to an air compressor on a VERY LOW (like 10PSI) setting. Pressurize the AC system with the air compressor. Take a spray bottle with soapy water in it and douse all of the AC lines, condensor, fittings, etc. If it starts to bubble, there's your leak. When you fix the leak, you are going to want to re-fill the system with new AC refrigerant and a can of AC lubricant Oil. Using the compressor air source can intoduce a little bit of dust into the system, and you don't want to just rely on the oil that is in with the refrigerant refill.
Good luck. AC leaks are a PITA.
  #4 (permalink)
Old 07-02-2009, 11:57 PM
Don't forget that the system will need to be evacuated before it's refilled.
__________________
  #5 (permalink)
Old 07-03-2009, 06:59 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
Quote:
ESPECIALLY if you were bumbling around with moisture-laden shop air.....
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
Tags
03 , 2006 , ac , compressor , expedition , fittings , ford , leak , procedure , refill
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
