Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 08:37 AM
K80 K80 is offline
K80 is starting off with a positive reputation.
Oil leak/Bed Plate
Ford dealer put oil leak detector in crankcase a few weeks back and said bring truck back and they would black light to find a small oil leak. I did so yesterday. Seems the leak is at the Bed Plate and they have to pull engine to replace the gasket. Truck is going in 7/8/09. Has anyone had an experience like this before?
  #2 (permalink)
Old 07-02-2009, 09:09 AM
69cj 69cj is offline
69cj has a good reputation on FTE. 69cj has a good reputation on FTE.
They did mine a year ago Feb. and so far dry as a bone. Took 3 days and my dealer said that they did it without pulling the engine or cab.
__________________
"05 F-250, 6.0, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, Magnefine p.s. filter, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
173rd Abn.
  #3 (permalink)
Old 07-02-2009, 11:16 AM
12ozd 12ozd is offline
mmmmm...beeer
12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE.
Quote:
How did they do that ?
I would think the engine would have to come out.
  #4 (permalink)
Old 07-02-2009, 12:48 PM
Mulepick's Avatar
Mulepick Mulepick is offline
Mulepick is starting off with a positive reputation.
I noticed a little oil on the forward end of the bell housing. Dealer checked with dye and black light. They pulled the engine, mounted it to a stand, and replaced the bed plate gaskets. They also replaced the rear mail seal while in there and steam cleaned the engine. 6 gaskets, 2 seals, 5qt trans fluid, adhesive, and dye. Total was $1750 on warranty. No TSBs referred. This was about 2 weeks ago.
Bob
__________________
2006 F-250 crew cab, SWB, SRW, PSD, Lariat/FX4, A/T, ARP studs, ISSPRO Pyro and Trans temp,Fumoto,
Mobil 1, BFG Radial T/A 285/70-17s,Helwig rear sway bar,Ride rite air bags/onboard compressor, coolant filter
2004 Lance 820 camper
  #5 (permalink)
Old 07-02-2009, 01:31 PM
blackestate blackestate is offline
blackestate is starting off with a positive reputation.
are you saying the warranty covered it? or it is under warranty, and you had to pay?
Other than the drip, how big of a concern is this?
  #6 (permalink)
Old 07-02-2009, 02:10 PM
Just passing on what th SA told me. Truck was done when I got there so I couldn't verify anything except that it hasn't leaked in 17 months, knock on wood.
__________________
"71 Triumph Trident
173rd Abn.
  #7 (permalink)
Old 07-02-2009, 04:29 PM
natem8301's Avatar
natem8301 natem8301 is offline
natem8301 is starting off with a positive reputation.
Quote:
Mine has "seepage" not a leak and my dealer**** told me I didnt need to fix it unless it turned into a leak. Whatever the hell that means lol
__________________
2003 F-250 6.0 315/70R17 BFG T/A KO, 4" turbo back exhaust, 6" Fabtech Lift, Front and back Pioneer 6X8 3-Ways, Infinity Kappa 122.7w sub in custom box, Sony XM-D9001GTR
  #8 (permalink)
Old 07-02-2009, 04:41 PM
Mulepick's Avatar
My vehicle is still under an extended warranty but I should think this would fall under the engine/powertrain warranty as well.
B
__________________
  #9 (permalink)
Old 07-02-2009, 06:30 PM
K80 K80 is offline
My Ford dealer (Smithtown, Long Island, NY) indicates that the engine will have to come out. Whether it is covered under the original engine or my expensive extended warranty is of no concern as my cost is zero. My truck has been in for various other problems since bought new. If these problems continue I will be looking for a new truck when the extended warranty runs out in 2011. I pull a 5,000 lb TT and the way the new F-150 is built and what it can tow I might consider it as the replacement. Mike
______________________
2005 F-250 crew cab, Lariat, SWB, Fumoto, Fly 4X4, Factory Tow/Haul
  #10 (permalink)
Old 07-03-2009, 10:02 PM
MeyerzF350 MeyerzF350 is offline
MeyerzF350 is starting off with a positive reputation.
Did my bed plate while in the engine. Not something you want to pay for out of warranty. Pulling the engine is the long hard way. I would take it to someone else.
__________________
2005 F350 Lariat CC 4x4 6.0L SRW
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
