Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 07:14 AM
KonaFocusSTX KonaFocusSTX is offline
KonaFocusSTX is starting off with a positive reputation.
Emergency...Need Quick Help
We are supposed to go camping tonight and I installed a Volant CAI last night in the hopes of getting a little extra power while towing our trailer. Everything was installed correctly but now the engine stumbles at idle. It takes a minute or so to happen after start up and throws codes P2196 & P2198 (too rich). It is a 2005 4.6L V8 STX and it ran perfect before this install. The CAI and filter are brand new and I don't see oil on the filter so I am stumped. I cleaned the MAF with MAF cleaner and let it air dry before reinstalling everything. I really appreciate any and all tips; we are supposed to head out this evening and I need to know whether or not I should replace the MAF or if it is something more simple. Thanks.
  #2 (permalink)
Old 07-02-2009, 07:31 AM
shorebird's Avatar
shorebird shorebird is online now
Wage Slave
2008 Ford F-150
shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all
Disconnect the battery for 30 minutes. Reconnect and drive for the computer to learn the new setting. I think that it is overcompensating and dumping excessive fuel into the intake to match the increased air flow.
__________________
2001 E-350SD V10 Triton 3.73LS; '05 & '07 Taurus SEL's;
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb
Unique Collision Center Towing & Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #3 (permalink)
Old 07-02-2009, 08:41 AM
I had the negative terminal disconnected for a couple hours while installing the CAI. It's a stupid question but disconnecting the negative terminal does reset the ECM right?
  #4 (permalink)
Old 07-02-2009, 09:22 AM
bridge's Avatar
bridge bridge is online now
This Ain't Rocket Surgery
2006 Ford F-150
bridge is gaining momentum as a positive member of FTE.
Yes, it should, especially for that long. Try it again and turn the lights on to make sure the system is completely discharged.
Do you have any other mods? Cat-back, Edge, etc?
__________________
2006 F-150 Lariat SuperCrew 5.4L 4x4
Dark Toreador Red
Edge Programmer
Westin Ultimate Bull Bar
AVIC-Z3
Magnaflow Dual Exhaust
Volant CAI
Remote Start/Alarm
Undercover Tonneau
Other Fords:
2006 EB Expedition 5.4L
2001 Eddie Bauer Expedition 5.4L
2002 Mustang Convertible GT 4.6L
  #5 (permalink)
Old 07-02-2009, 10:09 AM
I grew up in League City. Small world.
I don't have any other mods. To add more detail to my previous explanation, after the install, it doesn't start right up. Takes a couple seconds to start. Once the engine is running, it feels like vibration is coming from the engine although it doesn't stumble right away. After a minute or so, the RPMs periodically drop out near stall before going up again. The MAF reading (g/sec) is all over the place from 14-15 to 10-11 (without revving the engine). I read something about someone who thought there MAF was bad and they were advised to let it idle with the MAF unplugged. I did this and it started MUCH better and even idled ok for 10-15 seconds before the same "almost stall" began all over again.
  #6 (permalink)
Old 07-02-2009, 10:31 AM
bridge's Avatar
2006 Ford F-150
It sounds like some commmunication problems between the MAF and the PCM. Basically, it sounds like the PCM is sending your IAC bad info and not maintaining your idle speed properly. It doesn't happen often, but some trucks just don't like the Volant CAI.
You might want to put your stock unit back on and see if its still does it. Also, make sure that MAF is installed and seated properly. If I recall correctly, mine was a little difficult to seat. Also, check for any vacuum loss.
Small world indeed...if Obama keeps messing with NASA funding my world will get even smaller!
__________________
Dark Toreador Red
Edge Programmer
AVIC-Z3
Volant CAI
Remote Start/Alarm
Undercover Tonneau
Other Fords:
  #7 (permalink)
Old 07-02-2009, 10:48 AM
WhëëlMå1's Avatar
WhëëlMå1 WhëëlMå1 is offline
WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of
I recall Volant having all sorts of issues early on with their CAIs on the 04+ trucks. Did you buy this new, used, what? Frankly with the deadline you have... I would put the stock unit back on, reset the battery as mentioned.. and play another day.
__________________
Rich
FTE Guidelines
Support American Manufacturing!
"The next time some actor or rock star tells you what to think, tell them to **** off." - Dennis DeYoung
  #8 (permalink)
Old 07-02-2009, 08:02 PM
Update:
I called Volant Tech Support and they said to make sure the MAF sensor is in the right direction and to check for leaks....all stuff I've covered.
Got home from work and put original air intake back on and it works like a charm. I have no idea why it didn't work with the Volant. CAI seems to be one of the simplest mods but, again, I'm stumped.
At least I can ponder this stuff around a campfire with a frosty brew. Thanks for the replies and have a great Independence Day.
  #9 (permalink)
Old 07-02-2009, 08:45 PM
tylus's Avatar
tylus tylus is offline
Navy Nuclear Mach. Mate
2008 Ford Expedition
tylus has a good reputation on FTE. tylus has a good reputation on FTE.
sorry man
the 04-05 trucks have pretty restrictive ECU fuel maps
you probably need the newest PCM flash. then I'd bet your issues go right way
__________________
2008 Expedition EL - Hers....Bone Stock
2009 Mustang Bullitt - Mine..Not Quite Stock
Currently deployed. See y'all on the flip-side.
  #10 (permalink)
Old 07-02-2009, 09:29 PM
WhëëlMå1's Avatar
Quote:
You'd be surprised, there is a LOT of ingenuity that went into the stock design, and the interaction with the software. Im no fan of CAI upgrades, but thats fat to chew for a different day.
I intend on doing the same exact thing. Happy 4th to everyone!
__________________
Rich
FTE Guidelines
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
