Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 01:46 AM
gonzo1234 gonzo1234 is offline
gonzo1234 is starting off with a positive reputation.
360 distributor help
hey guys, i have a 68 mercury with a 360 i got an 4 bbl manifold and when i was removing the distributor i heard a metalic noise like something fell off. the only thing i can think of was it was the oil pump drive.i really dont want to have to pull the engine, is there a way to get it out without pulling the motor? how do i tell if it is really not where its supposed to be? any suggestions will be greatly appreciated.
  #2 (permalink)
Old 07-02-2009, 07:57 AM
60F100 60F100 is offline
60F100 is starting off with a positive reputation.
If you look down in the hole where the distributor was you should be able to see the shaft. You may need a flashlight. If it is not there you might get lucky and retrieve it with a long skinny magnet but the odds are against it. You should be able to drop the oil pan without completely removing the motor. Depends on how far it needs to be jacked up.
  #3 (permalink)
Old 07-02-2009, 12:18 PM
Madathlon's Avatar
Madathlon Madathlon is offline
Madathlon is starting off with a positive reputation.
There a retainer ring on the shaft, so if it has come out of the oil pump, and the retainer is still on it, you will never get it to come thru the hole, this retainer is for centering the shaft in the hole and is supposted to pervent it from comming out with the distributor. Best bet, Pull oil pan, pull Oil Pump and replace with a new shaft, Do not reuse the old one. many a times the old one fail suddenly when reinstalled, and at less then $10 it worth a piece of mind to replace it.
Needed Items
1/2 socket
Universal Joint
3 6in long ex,
New Oil pan gasket
Sealent ( Permatex "The Right Stuff" Recomended)
a 11/16 to 3/4 hand wrench.
Floor Jack, With blocks of wood.
If you need detailed instrations on how to, just ask
__________________
If it ante broken dont fix it.. If it is.. hit it with the biggest hammer U can find :P
  #4 (permalink)
Old 07-02-2009, 12:40 PM
bertha66's Avatar
bertha66 bertha66 is offline
1966 Ford F-100
bertha66 is starting off with a positive reputation.
One other thing to do is, if it did fall all the way to the bottom, leave it. Buy a new one, remove the retainer ring nad try to fish it down into the dist hole into the oil pump. The old shaft will not hurt anything in the pan, the oil pump has a screen to stop anything from going into the pump. I did this on my 66 4x4 F100.
__________________
Allen D
1966 F-100 4x4 with 390 GT engine
1990 Areostar 2wd XLT ext
1980 Bronco with 460
1964 Galaxie 500 with 428
Oregon Chapter Member: To join the Oregon Chapter, click HERE
  #5 (permalink)
Old 07-02-2009, 12:53 PM
Madathlon's Avatar
Quote:
NEVER ever ever Leave a object in a Oil Pan, One Odd bump, bad incline and that Shaft will end up in the crank assambilty. I know many say this is ok. and I have seen many do this with never having a problem, BUT I have also seen a $10 Oil shaft take out a complete engine. Had one go right thru the side of a block. Yes its a pain, and Yes its time comsuming, BUt a job done right the first time is worth all the time and money in the world.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
