Captain Chairs with Console Conversion - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-02-2009, 12:26 AM
RRS540 RRS540 is offline
RRS540 is starting off with a positive reputation.
Hey all, I'm new here and was wondering if anyone has done a conversion from a bench seat to the captains chairs, and how it's done. My Uncle's 2000 F-250 had the captains chairs with the console and I like it a lot better than the bench seat I have in my 05'. Any help? BTW would I have to get all new chairs, or just can I take out the center part and add on armrests.
Old 07-02-2009, 05:28 AM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Adding armrests would prove a bit difficult without some fab work.
If you find a set of capt's with a console it is a direct swap.
You have an actual bench or a 40/20/40 seat? If you have the 40/20/40 (which you probably do) then just get an 08 console. It bolts right in and no need for armrests since the lid is the armrest.
Old 07-02-2009, 12:51 PM
78bigbronco's Avatar
78bigbronco 78bigbronco is offline
78bigbronco is gaining momentum as a positive member of FTE.
Along the same lines... were there any differences in the seat mounts between the models? For my 09 which I know I am going to need to do something (either add console or swap in captains chairs) what year seats will fit? I dont need both just something to put my darn arm on lol. I havent even got it yet and realized I made a terrible mistake with the seats. It seams totaly asanine that Ford doesnt have any armrests or console on the bucket seats...
Old 07-02-2009, 02:16 PM
Yes, it is a 40/20/40, with the fold down console. It's just a personal preference with the captain's chairs. But the chairs look exactly the same as the captains with the console. I might as well get a whole new front, but the captains chair with floor console give the cab a more spacious feel, which I like. Thanks for all your responses.
Old 07-30-2010, 11:09 AM
modemboy modemboy is offline
modemboy is starting off with a positive reputation.
Captains Chairs
I have captains chair in my 250 and would prefer the 40/20/40 seats. My old 250 had captains chairs with arm rests and loved them. New chairs have a slight thigh support. Other than that the only difference is the counsel. I miss the armrest. You want to swap?
Old 07-30-2010, 11:22 AM
medplus medplus is offline
medplus is starting off with a positive reputation.
Quote:
I did this modification. I just removed the bench. Purchased used captains chairs and console for $600. Sold mine for $200. So cost me $400 bucks. I don't regret it at all. Just loose 1 person seating capacity. All the holes lined up. You will have 2 extra holes that you will just plug with the old bolts. All F250/F350 were prewired for power seats so the wires are already there and plug right in. The holes for the console are already in the floorboard, but you will need to put some sort of retainer bolt or I used a plastic insert that fit perfect in the hole and a screw screwed tightly into it.
Hope that helps. You will find interiors for the 99-07 all day long.
87 captains chairs in a 90 hotrod351 1987 - 1996 F150 & Larger F-Series Trucks 65 10-01-2016 07:52 AM
Bench Seat to Captains Chair Conversion - 1978 Bronco Phonmann 1967 - 1972 F-100 & Larger F-Series Trucks 1 07-10-2014 03:21 PM
Going from captains chairs to 40/20/40 bench, how do I do this swap? 90pioneer 1987 - 1996 F150 & Larger F-Series Trucks 11 10-20-2011 07:22 AM
Adding jump seat between rear captain's chairs kw_at_work Excursion - King of SUVs 4 02-08-2008 09:44 PM
Captains Chairs Swap cterrysgd 1999 to 2016 Super Duty 1 05-05-2005 12:42 AM
Tags
bench, bucket, captain, captains, chairs, console, conversion, convert, excursion, f150, f350, ford, front, seat, seats, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
