Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 11:16 PM
countryboy rob countryboy rob is offline
2005 Ford F-150
countryboy rob is starting off with a positive reputation.
Angry cb and electical problems
OK so i was trying to put my CB in that i got free from a friend and i got a cig lighter attachment for the wires and when i pluged it in to one of the cig lighters it blew the fueses an i cant find the ones in the fuese box so i can change them the owners manal doestnt give a good disciption and my warning sound for the seat belts isnt beebing any more so can some one help me so i can fix this problem ?
  #2 (permalink)
Old 07-01-2009, 11:17 PM
2005 Ford F-150
some one help me with this problem
  #3 (permalink)
Old 07-01-2009, 11:46 PM
GwarForAll1021's Avatar
GwarForAll1021 GwarForAll1021 is offline
GwarForAll1021 is starting off with a positive reputation.
i dont know about the fuses but wiring it to your battery is cake.
theres a rubber gromet behind the carpet thats behind your break petal. run 2 10G copper wires from there up then over to your battery. id say the wires not running up your dash and into your outlet is worth the extra sweat by far
  #4 (permalink)
Old 07-01-2009, 11:53 PM
2005 Ford F-150
ok thanks but do u think the waring sound for the seat belt and the the 12 cig lighter not working could cause computer problems later on down the road ?
  #5 (permalink)
Old 07-02-2009, 12:16 AM
im not an expert but to me outside of the inconvenience of not having that outlet for the future sucks. as for computer problems ... i cant see what it could ever screw up.
but not having the seat belt dinger sounds like hell of a good thing haha
your owners manual should have a fuse list of where and what fuse you should need.
  #6 (permalink)
Old 07-02-2009, 12:48 AM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
2005 Ford F-150
FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all
From the '05 manual...
Quote:
#41 20A* Cigar lighter, Diagnostic connector power
If you are planning on direct wiring the radio don't forget to fuse both wires. The Pos.and Neg. being fused seems to SOP now 'n days (not so much if using a chassis gnd)
__________________
-Rich
Chapters / 2004-2010 F150 / 2011 F100 Moderator
****Join the South Carolina Chapter here!!!***
..Or your own state chapter Here
  #7 (permalink)
Old 07-02-2009, 11:09 AM
2005 Ford F-150
i changed that fuse already an it works for the regular cig lighter but i have to other cig lighters as i call them theres a 12 volt power outlet in the front and a standard in the back those 2 arent workin now and i cant find out wat they are in the manual
  #8 (permalink)
Old 07-02-2009, 01:18 PM
2005 Ford F-150
So you blew all of the fuses related to the power points?
On Edit:
#37 20A* Rear power point
#39 20A* Instrument panel power point
Should be the 3rd row up from the bottom and more on the right side of the box (the 1st and 3rd positions from right.)
__________________
-Rich
  #9 (permalink)
Old 07-02-2009, 10:10 PM
2005 Ford F-150
do u kno wat fuse is for the seat belt warning light indicator
  #10 (permalink)
Old 07-02-2009, 11:29 PM
2005 Ford F-150
Do you still have parking lamps? If not, it is fuse #6
If that Ohms out okay try fuse #18.
I was trying to trace back using a '05 wiring drawing package. The fuse number seems kind of blurry on the paper.
__________________
-Rich
  #11 (permalink)
Old 07-04-2009, 03:43 PM
shorebird's Avatar
shorebird shorebird is online now
Wage Slave
2008 Ford F-150
shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all
Go here; http://www.motorcraftservice.com/pubs/content/~WO5F12/~MUS~LEN/36/05f12og5e.pdf Fuse info starting on page 226.
__________________
2001 E-350SD V10 Triton 3.73LS; '05 & '07 Taurus SEL's;
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb
Unique Collision Center Towing & Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #12 (permalink)
Old 07-05-2009, 04:10 AM
2005 Ford F-150
Quote:
Originally Posted by shorebird View Post
He mentioned something in his original post that he had a manual, just had problems deciphering the descriptions somehow...
__________________
-Rich
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
