Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 10:18 PM
oldblue92's Avatar
oldblue92 oldblue92 is offline
1952 Ford F-250
oldblue92 is starting off with a positive reputation.
Oil Filter Adaptor Kit Go or No?- 6 Cyl 215 1952
I can't figure out if I should send this kit back or not...
The adaptor doesn't screw in where the old centerbolt used to. (The cover is long gone.) It looks like the centerbolt used to screw in though the center of a 1-1/8" hex fitting.
My shop manual doesn't show if the 1-1/8" holds the pump together or not, plus, the pad to adaptor plate clearance is not looking too promising. But the adaptor plate *IS* the right diameter.
(The threading on the oil filter adaptor, opposite the spin-on-filter side, is large and looks close to a garden hose thread.)
Should I unscrew the 1-1/8" hex to see it the adaptor fits? Then see if the plate compresses it's gasket? Or should I send it back?
Thanks... I'm trying to be patient and do things slowly, asking people who know, instead of breaking two things for every one I fix. (The usual rate :P)
  #2 (permalink)
Old 07-02-2009, 12:37 AM
Old F1 Old F1 is offline
Old F1 is starting off with a positive reputation.
Is this what you have? (cost me $ 20.00 to post the picture)
http://www.ford-trucks.com/forums/at...1&d=1246509051
  #3 (permalink)
Old 07-02-2009, 12:44 AM
oldblue92's Avatar
1952 Ford F-250
Yes, looks like it. $20???!!!
  #4 (permalink)
Old 07-02-2009, 01:40 AM
Yes, I think that you remove the hex fitting that you have and replace it with the gasket , the plate, and then the threaded adaptor.
I got so frustrated with trying to get my gallery to work I bought a membership to post pictures. I think it is a premeditated conspiracy!
(how come the smiles keep changing positions?)
  #5 (permalink)
Old 07-02-2009, 02:39 AM
Fomoko1's Avatar
Fomoko1 Fomoko1 is offline
Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of Fomoko1 has much to be proud of
Quote:
I don`t know, guess it`s to ''freshen up'' the site or for more variety.
I don`t like it that much either, at times I have go to the More smilie page to find the one I want.
I`ve got an old adapter kit but I might have to buy the kit if I can`t find that rubber gasket.......
__________________
Fomoko1..Morris
Chapter Leader Manitoba/Saskatchewan
1927 Model T Touring
53 M350, 56, 57 & 71 F350, 53 & 56 M100
89 & 98 Ranger XLT s/cab
92 F250 XLT Super Cab 4X4, 05 F350 6.0 4X4Lariat Crew
65/67 Mustang Fastbacks/68 convertible
57 Ford 800 tractor, 86 & 88-LN 8000 Ford trucks
  #6 (permalink)
Old 07-02-2009, 10:09 AM
stockcar nut's Avatar
stockcar nut stockcar nut is offline
stockcar nut is starting off with a positive reputation.
Morris, if all else fails to locate that gasket then go get an oil filter for a canister oil filter. It has the same gasket. About $5 at Advance Auto Parts. Tom
__________________
Last week I couldn't even spell mukanick and now I are one !!!
  #7 (permalink)
Old 07-02-2009, 10:55 AM
Quote:
Originally Posted by stockcar nut View Post
Morris, About $5 at Advance Auto Parts. Tom
That would be about $ 10.00 for Morris; ……..he lives in the land of the expensive slow socialized medical system.
Yep, it’s the same gasket as in the canister filter, you might find a gasket in someone’s junk at a swap meet or old shop?
  #8 (permalink)
Old 07-03-2009, 12:21 AM
Fomoko1's Avatar
Your right about the $10...LOL!
I`m sure I can come up with that flat gasket, I may even have one laying around if I look long and hard enough.
__________________
Fomoko1..Morris
  #9 (permalink)
Old 07-03-2009, 09:36 PM
oldblue92's Avatar
1952 Ford F-250
It won't budge! I really don't want to use lead hammers and blowtorches. (At least I read how to preserve the paint with some water.) Sorry, I hadn't planned on getting frustrated or stopped this time around.
  #10 (permalink)
Old 07-07-2009, 08:41 PM
oldblue92's Avatar
1952 Ford F-250
Having trouble here, there is only 1/8" sticking out and I have started to round two edges.
I could use some advise. My electric impact driver will not fit in the F-2's engine compartment. I may pull the engine, but right now I really want to get this Oil filter taken care of, buy the battery and start the 215. A really good mechanic said he'd help me once I got to a certain point... That's all I need to take care of.
Should I try to track down a new (old) oil filter housing and do it the old way? Do any of those "Turn rounded bolt" tools actually work? Which ones? Should I try a torch? Propane or Acetal? Would a torch destroy the oil pump in the 215? I am open to any suggestions. WD-40 and PB Blaster have not helped, neither has some lead hammer taps.
  #11 (permalink)
Old 07-07-2009, 09:54 PM
Sure sounds like trouble. The only thing that I can thing of is a six point socket (not 12) with the front edge ground flat so that the socket grabs more nut. Sorry.
  #12 (permalink)
Old 07-11-2009, 06:14 PM
oldblue92's Avatar
1952 Ford F-250
Thanks Old F1, the ground six point socket finally did the trick - What a relief! The adaptor and filter fit perfectly and they're ready to go.
It feels so good when things come together.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
