Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 09:46 PM
redneckson redneckson is offline
redneckson is starting off with a positive reputation.
96 ford bronco
Hi guys i have a 96 ford bronco. i had the 8.8 rear end pulled out and had a 9 inch put in. after all the work was done i noticed that it was shifting hard and i had no speedometer and no overdrive. the mechanics that did the work said that it was a speedometer sensor that would not clip into the 9 inch and that i would have to take it to a dealor to see what they could do. can somebody please help me i have spent to much money already and realy dont want to spend alot more just to go muddin. your help would be greatly appreciated
  #2 (permalink)
Old 07-01-2009, 11:10 PM
b4hntn b4hntn is offline
b4hntn is starting off with a positive reputation.
First of all, Welcome to FTE.
I'm sure someone will be along soon. I have an answer but not sure I am correct. If I am, others are more tactful than me and can break it to you more gently.
__________________
If your ignition control module is a black Motorcraft (CCD system) do not replace it with a gray one (Push Start system). The wiring harness is different.
FTE is great! Be a supporter to keep this forum going. 94 5.8 EB, towing package, K & N drop in, MSD Blaster, 9 mm Ford Racing Wires, mechanical oil and temp guages and the rest all stock.
  #3 (permalink)
Old 07-01-2009, 11:12 PM
dt75flh's Avatar
dt75flh dt75flh is offline
dt75flh is starting off with a positive reputation.
I believe your VSS was in the rear 8.8 diff (tone ring on the gear)....which your computer uses for a signal for the speedo and the tranny.....
__________________
08 job 1 F350 4x4 CC/LB King ranch 35"s 4.10's 60 gal fuel tank
71 Mach 1 with 1990 FI/AOD 5.0 HO motor
96 Bronco XLT 5.8 32's
85 Toyota PU rock krawler with dual cases, detroits
  #4 (permalink)
Old 07-01-2009, 11:35 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
1992 Ford Bronco
greystreak92 is gaining momentum as a positive member of FTE. greystreak92 is gaining momentum as a positive member of FTE.
First off, welcome to FTE and the Big Bronco Forum. I only wish that you had posted this quandary BEFORE doing the swap. We would have issued the following warning...
Without the VSS your transmission won't ever shift properly, your speedometer will never function properly and your cruise control will never work. I know the E4OD has no provision for putting a VSS in it so moving it up to the transmission isn't an option. I am not certain about the newer auto that some 96's got. There may be an aftermarket kit to put a VSS inline somewhere but I couldn't tell you who makes it. Either way, you have to find a way to keep the VSS or risk destroying the transmission and never knowing how fast you are going. The ECM simply won't control shift functions and everything else that relies on VSS signal without this sensor. Your ABS won't work in the rear either and may end up eventually affecting the front braking as well as the ABS computer also uses the VSS to determine wheel slip in the rear axle and without ANY signal it goes into fail-safe mode. You would be better off finding a D60 with a VSS provision or staying with the 8.8.
__________________
Only stupid question is the one you don't ask.
1993 Bronco XLT 5.0, E4OD (at the moment)
1992 F-150 XLT 4.9, M5 (at the moment)
UPDATED! Big Bronco FAQ's
  #5 (permalink)
Old 07-02-2009, 12:40 AM
H2OnO2's Avatar
H2OnO2 H2OnO2 is offline
H2OnO2 is starting off with a positive reputation.
Quote:
There was a Dana 60 with a VSS provision?
redneckson, sorry for the hijack. I know you are burnt on spending $ but your mechanic may have left you stuck. For just a few (hundred) dollars more: http://blogs.dieselpowermag.com/6503...rds/index.html
Or
http://www.breaautoelectric.com/products/products1.html
Or modify your 9" 3rd member to take a tone ring. Pic of a VSS tone ring in a modified 9 inch 3rd member:
http://www.race-dezert.com/forum/att...93&d=991366261 from this thread http://www.race-dezert.com/forum/showthread.php?t=287
Good luck with your project!
__________________
2001 F-150 daily driver *$howing her mile$*
1990 EB Bronco *$imple fixe$* in work
1991 XLT Bronco *$tealing the $potlight* for now
straightjacket/mental hospital room *comming soon*
  #6 (permalink)
Old 07-02-2009, 09:55 AM
alxsnmr alxsnmr is offline
1991 Ford Bronco
alxsnmr is gaining momentum as a positive member of FTE.
I think GreyStreak meant he would have been better off with the 10.25 and a D60 front end if he wanted to upgrade his axles, so that 1. he could have kept the VSS for speedo and trans shifting, and 2. would have been an upgrade. The other option would have been to modify the 8.8 for better axle bearings that didnt wear on the axles. If he truely wants to keep the 9 in, either make a VSS for the 9 inch, or move the VSS up to the 87-91 postion on the transfer case output shaft.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, custom trimmed rear fenders finished in rust.
2009 Fusion SE 2.3L 5spd Red/black cloth n leather
  #7 (permalink)
Old 07-02-2009, 11:22 AM
what did you mean by this alxsnmr. how do i do that. thank you everyone for their input it is greatly appreciated.
  #8 (permalink)
Old 07-02-2009, 08:27 PM
1991 Ford Bronco
92 to 96/97 had a combined VSS/ABS sensor in the rear axle. 87 to 91 Fords used a VSS in line with the speedo cable on the output shaft of the transfer case, or in the case of 2wd's on the output shaft of the transmission. It was often considered just a VSS for the cruise only but it was also used by the computer as a VSS. It doesnt have a tone ring but uses a speedo gear with revelotions to determine vehicle speed. 87 to 91's sensor in the rear axle was for the ABS only. I am sorry to say but like greystreak said your first mistake was swapping an axle in that wouldnt support the VSS module that you need for your transmission.
__________________
  #9 (permalink)
Old 07-02-2009, 09:23 PM
ok thank you guys so much for your help. i checked up on some of the stuff that H2OnO2 posted and i think that i am going to invest on a relocator at the transfer case. it seems pretty simple and not to expensive. again thank you all so much. i appreciate it very much.
  #10 (permalink)
Old 07-04-2009, 04:02 AM
H2OnO2's Avatar
If you go thru with it please get back to this thread and post results/pics, no doubt others are facing the same issue and your experience could help!
__________________
  #11 (permalink)
Old 07-04-2009, 10:34 AM
1992 Ford Bronco
Quote:
Sure! 3/4 and 1 ton F-series equipped with the E4OD needed the VSS.
__________________
  #12 (permalink)
Old 07-04-2009, 01:10 PM
1991 Ford Bronco
Dana 60's were not very common, if at all, as rear axles for 3/4 to 1 ton trucks mid 80's onward. Very common as front axles for 1 tons from late 70s on though. If it was present as the rear end I think the VSS was moved to the transfer case.
__________________
  #13 (permalink)
Old 07-04-2009, 03:41 PM
masseysbronco's Avatar
masseysbronco masseysbronco is offline
masseysbronco is starting off with a positive reputation.
Good opportunity to switch to manual shift transfer case at the same time if you wanted to. Assuming you don't allready have one.
__________________
93 EB 351 E4OD
200,000 miles
Do it right the first time!
  #14 (permalink)
Old 07-04-2009, 07:30 PM
will do h2ono2 as soon as it is done i will take some pics and post them again thank you for the help.
Tags
96 , 9inch , auto , bronco , control , cruise , find , ford , kit , put , relocator , shifting , trans , vss
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
