Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 09:33 PM
SeannyBoy84's Avatar
SeannyBoy84 SeannyBoy84 is offline
SeannyBoy84 is starting off with a positive reputation.
Unhappy Truck Won't Start: Theft Light Blinking, Fuel Pump Relay...
Hey everyone, my truck won't start and I need some insight.
I was driving home on the highway the other night, my check engine light on, and the engine died. First thing I noticed is that the "theft" light would begin blinking with the key in the "on" position". Also, in the "on" position, the #4 relay (fuel pump) in the power box under the hood would continuously click/rattle. The truck would not start.
Took a look at it after it was towed home. The battery seems fine. The truck turns but it doesn't start. We smelled a lot of gas and found that there was fuel dripping around the exhaust manifold area. I'm not sure if this relates to the relay. Tried replacing and that didn't work.
I miss her already and any advice would be great here. Let me know if you need anything else. What else should I take a look at, should I check any fuses, etc. Thanks.
__________________
97 Expedition 4.6 4x4
  #2 (permalink)
Old 07-02-2009, 12:39 AM
alloro alloro is offline
alloro is gaining momentum as a positive member of FTE. alloro is gaining momentum as a positive member of FTE.
A blinking theft light usually means that the onboard PATS cannot read the chip in the key. That being the case, the PATS prevents the engine from being started.
__________________
If you like the advice you get, be sure and click the left red "Add to Reputation" button
to the right of the word "permalink" at the top right of the poster's message window.
  #3 (permalink)
Old 07-03-2009, 10:58 AM
Larry85355 Larry85355 is offline
Larry85355 is starting off with a positive reputation.
Had the same thing happen to me.
It was the battery.
Tags
blinking , expedition , explorer , f150 , foed , ford , fuel , light , pump , relay , theft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
