Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 09:32 PM
djmac djmac is offline
djmac is starting off with a positive reputation.
Rattling down under after rebuild
I just finished going thru my 92 460 and after 100 miles or so I have a rattling in the lower end in fact I can feel it rattle on the rear of the oil pan. The rebuild included a crank grind, new bearings (10 under) rings etc. Motor runs good and oil pressure at idle is at 40 and at cruising is around 70. Obviously I have to drop the pan and outside of making sure the pump and oil sump is on tight what else should I be looking for?
__________________
82 Jeep J10 with 92 460 w/ CUSTOMEFIS Muliport 1 Ton Axles
  #2 (permalink)
Old 07-08-2009, 12:29 AM
johnboy427's Avatar
johnboy427 johnboy427 is offline
johnboy427 is starting off with a positive reputation.
Make sure the flywheel bolts aren't backing out.
-Johnboy
__________________
-1979 F-250 4X4 351 Cleveland 4spd
-1993 Probe GT 2.5L 5spd
-2009 Focus coupe 5spd Significant others DD
  #3 (permalink)
Old 07-08-2009, 11:51 PM
2losteve 2losteve is offline
2losteve is starting off with a positive reputation.
Quote:
Those bearings hopefully are .010 over rather than under.
  #4 (permalink)
Old 07-09-2009, 12:15 AM
johnboy427's Avatar
.010 on the crank would be under bores go over, you are taking metal off so you need smaller bearings.
-Johnboy
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
