Go Back   Ford Truck Enthusiasts Forums > Misc. > Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-02-2009, 01:43 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
just to verify it before you learn to dismantle your dash, get a DMM. VDC, and put one probe on the amp's ground and the other on a good ground on the firewall. With everything running, if you have a ground loop you should see 0.1v or more. If it's less than 0.1v, the connection is adequate between the two points and you don't need to share the ground.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #17 (permalink)
Old 07-02-2009, 02:01 PM
Karl4Cat's Avatar
Karl4Cat Karl4Cat is offline
Karl4Cat is starting off with a positive reputation.
.255 mv is the reading I get.
__________________
09 - 250SD - 4X4 - V10 - Auto - Lariat - SC - SB - 4:30's - Loaded - 350 Blocks - SCT X3 by 5Star - Extang Trifecta Tonneau - Rhino Liner - Escort Passport 9500ix - Garmin Nuvi 255w - Bazooka - Streamlight LED - Fisher XtremeV SS
  #18 (permalink)
Old 07-02-2009, 02:05 PM
Karl4Cat's Avatar
PS You guys have any idea why the ground loop isolator cut the output so much? I've used them in the past as a quick fix with no issues.
__________________
  #19 (permalink)
Old 07-02-2009, 03:28 PM
ReAX's Avatar
2002 Ford F-250
They are a band aid product. The band aid usually includes components that smooth out the voltage/current going through it. Which is nice if you want DC power that fairly consistent, but the audio is highly variable AC.
I want to say they use an inductor in them, which smooths out the current and has an impedance. It's like connecting speakers in series, your adding the resistance together to give a higher total resistance on the amp.
__________________
  #20 (permalink)
Old 07-02-2009, 03:30 PM
AudioNutz's Avatar
AudioNutz AudioNutz is offline
AudioNutz is starting off with a positive reputation.
Not to mention, they never work. They just cut the output down so you can't hear the noise, in hopes that you won't notice the cut in signal.
__________________
-Bill
2003 IASCA Amateur Street World Champion
2003 SLAP Amateur Street National Champion
Linear Power - Dynaudio - Sony - Scosche
My Little Truck My Other Projects
  #21 (permalink)
Old 07-02-2009, 06:59 PM
Karl4Cat's Avatar
Well, problem solved. I took the easy way and tried a different brand of isolator made by PAC. Perfect! No signal and frequency loss like the Radio Shack model. I actually googled the problem and found others said the same about the Shack ones. So, I went to a local shop and presto fixo. What an outstanding addition to the factory sub (the Bazooka) without blowing too much coin. Thanks for the info guys. I'm glad I didn't have to use it all and dig further...
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
