Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > New Jersey Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
New Jersey Chapter Join Chapter Leader: sddesigns
  #1 (permalink)
Old 07-01-2009, 08:00 PM
mrfox0246 mrfox0246 is offline
1954 Ford F-100
mrfox0246 is starting off with a positive reputation.
My rear - to rebuild or not
HAVE A '54, WITH A 70's SOMETHING FORD 9" REAR. NEED TO SET UP THE CARRIER. PROBABLY BE SMART TO REPLACE ALL THE BEARINGS AND SEALS. ALAS, MY TRUSTED MECHANIC GETS $90/hr SO I'M PROB LOOKING AT $600-700 WHEN EVERYTHING IS DONE. MAYBE A TRIP TO THE JUNK YARD IS IN ORDER. WHAT ARE SOME POPULAR REAR'S THAT HAVE BEEN USED? WHAT YEARS TO LOOK FOR. I UNDERSTAND THERE MAY BE SOME FABRICATING IF I OPT FOR ANOTHER REAR. WOULD LIKE TO HAVE A 5 on 5 1/2 LUG SPACING. CAN ANYONE RECOMMEND A NJ/NY/PA SHOP THAT COULD REBUILD MY REAR AT A REASONABLE COST THANKS
  #2 (permalink)
Old 07-02-2009, 12:51 PM
frederic's Avatar
frederic frederic is offline
Garage is empty, add now
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
Why not rebuild it yourself. You can rebuild it underneath the truck on jackstands or you can take it completely out and put it on sawhorses and work on it without wrenching your back (I'm out of shape, these types of decisions are important).
Just replace all the bearings, inspect the wear on the ring and pinion gears, make sure everything feels tight without wobble. Setting the backlash on a rear axle isn't very difficult and you can use the official plastic crusable strips (cheap) or even playdoah.
I've done a few myself over the years and it's not really that difficult to do yourself.
  #3 (permalink)
Old 07-02-2009, 04:11 PM
1954 Ford F-100
Thanks for the feedback, yeah, I know I can replace the bearings and seals, its the carrier backlash that I'm not sure of. Any instructural info out there, never heard of crushable strips but it makes sence ; probably what the garage would use anyway.
  #4 (permalink)
Old 07-02-2009, 04:47 PM
jerzydiver's Avatar
jerzydiver jerzydiver is offline
2006 Ford F-350
jerzydiver is starting off with a positive reputation.
Do not get rid of the 9 inch great rear ends. and as far as working on it even easier since the carrier is removed by pulling the axles and then the carrier bolts to remove the whole third member
__________________
www.RhinoKustoms.com
06 F350 XLT Crew Cab LWB FX4, power Captain Chairs / Snow Plow Packsage camper package / tow command / Amsoil oil bypass filter/ Billet Badges / A Pillar Quad gauges / overhead quad gauges / ExtremeAir compressor / Trian Air Horns /
  #5 (permalink)
Old 07-02-2009, 08:10 PM
1954 Ford F-100
Yup, I agree, and I have some money and time tied up back there also; new wheel cylinbders, new brake pads and new drums. I need to get educated on how to set the carrier gear lash (I think thats the correct term). Time to start Internet searching
  #6 (permalink)
Old 07-03-2009, 01:39 PM
tjc transport's Avatar
tjc transport tjc transport is offline
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
where are you located??
there is a very good mechanic that lives in Hazlet that i use when i need differential work done. when he does it on the side at his house, he can give you a very good price.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
  #7 (permalink)
Old 07-03-2009, 02:17 PM
frederic's Avatar
Gear lash is rather simple. Essentially you stick these plastic strips into the gears as they mesh, then measure the thickness after squashing them. The thickness should be approximately equal to the manufacturer's specification, and if not you adjust how far the pinion sticks out into the ring gear. The usual adjustment method is required - shims
If it's too lose it will chatter and wear out quickly, and possibly break as the edges of the teeth will be all that is meshing, and if it's too tight the edge of the teeth will bang on the body of the ring gear, and something will break.
I don't know offhand what the lash should be on a 9" but once you have that figure you can have a go at it.
  #8 (permalink)
Old 07-03-2009, 02:30 PM
1954 Ford F-100
Good information all - thanks - I'm starting to feel I can do this - once I get the clearences. I live in Morris County NW Jersey; about 10 miles northwest of Morristown -Dover
  #9 (permalink)
Old 07-03-2009, 03:51 PM
frederic's Avatar
Measuring backlash isn't a big deal with the little plastic sticks, or playdouh. Taking the thing apart to shim it is a bit more work, and more than likely you'll have to do it twice to get it right since you've never done it before. Don't fret, it's par for the course.
  #10 (permalink)
Old 07-03-2009, 04:16 PM
Quote:
Steve, sddesigns is rite up the hill from you in Wharton. he may know of someone up there that can cut you a deal.
he is out on the boat in lake hopatcong today. but he will be in later.
__________________
Tom
  #11 (permalink)
Old 07-03-2009, 05:39 PM
1954 Ford F-100
SD Designs?
What kind of business is that?
  #12 (permalink)
Old 07-03-2009, 08:09 PM
not sure. i think he does computer graphics layout.
__________________
Tom
Tags
ford, pa, rears, rebuilding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
