Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 08:50 PM
gatorman21218 gatorman21218 is offline
gatorman21218 is starting off with a positive reputation.
'91 7.3l radiator question
my 1991 F-250 has 255k miles on. While she runs fine I am a little concerned about my cooling system. The reservoir is broken where the hose enters it so it does not create a seal. The radiator leaks about a gallon of fluid every 3-4k mi. Looking in filler hole I can see all the fins encrusted with white gunk. She has never overheated on me but should I be worried about cavitation? I do not have a turbo system. What do y'all think?
  #2 (permalink)
Old 07-01-2009, 10:25 PM
harleyjohn45's Avatar
harleyjohn45 harleyjohn45 is offline
harleyjohn45 is starting off with a positive reputation.
Quote:
You need to have the radiator repaired. some can be rodded out while others may need a recore. The leak can be soldered.
__________________
1991 7.3 liter non-turbo F-350 superduty/12' dump bed.
  #3 (permalink)
Old 07-01-2009, 10:32 PM
ok i figured that much but what about the reservoir?
  #4 (permalink)
Old 07-02-2009, 12:04 AM
get it soldered, flush the radfiator out good and add new coolant and Napa cool. Since its not over heating now, Its probably good. With that leak in the reservoir, you cannot run a pressure cap.
__________________
  #5 (permalink)
Old 07-02-2009, 12:06 AM
you man can get it soldered right on the truck.
__________________
  #6 (permalink)
Old 07-03-2009, 09:49 PM
no the reservoir is plastic and it has broken off where the hose enters it. can i use jbweld or something like that?
  #7 (permalink)
Old 07-03-2009, 10:55 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
On my tank the hose extends into the tank.
Make sure you cut a V in the end of the hose so it don't get sucked against the side or bottom of the tank and you will be fine.
Not sure if they changed the tank style on later years or not.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #8 (permalink)
Old 07-03-2009, 11:20 PM
that is exactly the way mine is i was just wondering if it mattered that the plastic was broken where the hose enters and there is a little plastic protrusion where it clamps around the hose.
  #9 (permalink)
Old 07-03-2009, 11:22 PM
now what about the cavitation should i be worried about that? does it matter that it is gunked up inside can i just add the stuff or do i need to get it recored?
  #10 (permalink)
Old 07-04-2009, 12:42 AM
dakotajeep's Avatar
dakotajeep dakotajeep is offline
dakotajeep is starting off with a positive reputation.
gatorman,
Where are you at? I could send you my old one if you wanted to have it boiled out and see if it would work?
Just let me know....
Thad
__________________
1994 F350 XL Crewcab 4x4 SRW 7.3 E4OD Banks Turbo & "Custom" Exhaust
Dana 60 Sterling 10.25 3.55 285/75 16 Treadwright Retreads MTG's (love these tires), Pyro Install and Tekonsha Voyager Brake controller!
A little rough but its a truck not a show car!!!
In its former life it worked for the US GOVT
  #11 (permalink)
Old 07-04-2009, 12:59 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all
I do not believe cavitation is related to the white stuff inside the radiator, unless that means the system was not well taken care of, so it probably doesn't have the good anti-feeeze in it.
My radiator is in the same condition. I took mine to a radiator shop, but he would not touch it. Besides the white stuff inside, it also had white stuff growing on the outside at the bottom. He said this is a sign it's been seeping at the bottom, and the hard water(the white stuff) has been somewhat sealing it off. He said if he dipped it to clean it, it would surely leak and would be too far gone to fix.
He told me to get a new radiator, or I could try and keep running this one and see how long it lasts. I am saving up right now to buy a new one. They are about $350 at the local parts stores. I am still running the old one, but I also have to add coolant to the overflow bottle once in awhile. I also put a 7lb cap on it to help it out a little bit.
__________________
Dave F
1989 F250 XLT Diesel
  #12 (permalink)
Old 07-04-2009, 11:06 AM
yeah i'm just gonna add some SCA's and wait till she doesnt want to go any farther. thanks for your help. BTW what SCA do yall recommend?
  #13 (permalink)
Old 07-04-2009, 12:06 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE.
Dont add the SCA's if you have regular coolant. You need to be running a low silicate antifreeze and distilled water. The SCA's mix with the silicates in regular antifreeze and the minerals in tap water and can form a slugde plugging up portions of your cooling system.
I am going through the process of changing out my cooling system since I dont know what the PO was running. I had to replace my water pump, but I am getting the radiator cleaned and will remove as much coolant from the rest of the system as possible. I went to the cummins shop and got 8 gallons of 50/50 fleetguard antifreeze which already has the SCA's added to it.
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS Turbo 173hp/335tq
1986 F-250 HD XLT Lariat SC 4X4 460/C6
1985 F-250 HD XLT Lariat SC 4X4 460/5spd
1974 F-250 HD 2wd-360/C6
1967 Ford Mustang-351W/4spd
  #14 (permalink)
Old 07-04-2009, 12:50 PM
1986 Ford F-250
I am not a fan of running antifreeze with silicates in it either.
The silicates are added to antifreeze to protect the aluminum in modern engines.
There is no aluminum in our engines, heater core and radiator are both brass, so there is no need for silicates in our cooling systems.
And yes, the SCA can cause the silicates to precipitate out of the coolant.
Solder bloom can happen normally, but is definitely aggravated by tap water being added to the cooling system.
Using either distilled water and full strength antifreeze or the pre-diluted 50/50 mix are the best options.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #15 (permalink)
Old 07-04-2009, 02:17 PM
I have just been using the prestone green stuff and distilled water. so if i flush her out and put in the heavy duty truck stuff that they have that would be sufficient? i forget the name of it. i used it in our boat before we sold it. is there a good flushing chemical i should use?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
