Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 08:24 PM
goldsmje goldsmje is offline
goldsmje is starting off with a positive reputation.
Battery light intermittent flashes??
I've got a 2002 7.3 diesel Ex. A few months back I noticed that my battery light would come on at idle but when I revd the engine it would go out. Eventually the battery died and I had to jump start it. I took it to the shop and they replaced the alernator, which has a lifetime warrantly on it. A few weeks after it was replaced, I noticed that the battery light would randomly come on and then go out, and it would even do it while driving at highway speeds. Took it back to the shop and they replaced the alternator again under the lifetime warranty. SHortly after that replacement, I was towing my camper at highway speeds and the battery light would again randomly come off and then go out. I haven't taken back to the shop yet, as I suspect they will just take the easy route and replace the alternator again under warranty. Does this sound like three bad alternators in that short of a period?? Any other suggestions or ideas on what it might be??
__________________
2002 Excursion 7.3 PSD, (80,000 miles Replaced Upper and Lower driver side ball joints, driver side front wheel bearing, installed Helwig rear sway bar). Tow 2009 Jayco Octane 24Z Toyhauler, 2003 Roadstar 1600 and V-star 1100, dual cam W/D hitch.
  #2 (permalink)
Old 07-01-2009, 09:05 PM
hofuf hofuf is offline
hofuf is gaining momentum as a positive member of FTE.
Did they charge the battery and test it?
  #3 (permalink)
Old 07-01-2009, 09:40 PM
I'm not sure, but I will ask. Maybe they were counting on the new alternator to take care of that??
__________________
  #4 (permalink)
Old 07-01-2009, 10:31 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
I'd bet that the batteries took out your alt if they were dead when they were replaced. You get one or maybe two dead alts off the shelf, but three is hard to believe.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #5 (permalink)
Old 07-02-2009, 02:14 AM
Monsta's Avatar
Monsta Monsta is offline
Sit. Stay.
2005 Ford Excursion
Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of
From another Excursion forum...deep in the forum...
He tried three new altenators on it and they all kept the light on.
Then he opened the last altenator, and as they in most cases are either rebuilt or manufactured somewhere with less expensive workforce, he found the problem. The regulator inside had too much protective wax on it so that it could't get the ground properly. Little sandpaper to connection and life became easier again = light turned OFF.
Parently the other "new" parts had the same problem, as they came from same supplier.
All readings in meter shows normal and light stays off.
http://www.supermotors.net/clubs/for...&page=1&rpp=10
__________________
Ken
Cats; nasty creatures...
Tags
73 , battery , dead , excursion , flash , flashing , ford , intermittent , light , lights
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
