Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 07:42 PM
Automator's Avatar
Automator Automator is offline
Automator is gaining momentum as a positive member of FTE.
Flow Through Tailgate
I am looking to put a flow-through tailgate on my truck (in signature) and would like to know if anyone here has one and what they think of it. I took my tailgate off about a month ago and got about 0.3 mpg increase (hand calculated). I just don't like the look without a tailgate and want to put something in it's place.
__________________
-Dave
'01 F350 Lariat, Crew, 4x4, DRW, LB, 7.3L PSD, 320K Miles
Zoodad Mod, Foil Delete, S&B Intake, Auto Meter Gauges, Fumoto, WW & HPX
** Coming : 4" Exhaust, Tuner
There's no place like 127.0.0.1
  #2 (permalink)
Old 07-01-2009, 09:00 PM
bkcowboss bkcowboss is offline
U R A Hoser if U R not A
bkcowboss is gaining momentum as a positive member of FTE.
the flow through tailgate increases drag so it will decrease mileage compared to the solid gate, it acts like a parachute compared to the tailgate acting like an air foil....
__________________
Bryan
2003 Excursion 180,000 mi
Where can I order Blinker Fluid?
  #3 (permalink)
Old 07-01-2009, 09:47 PM
F350-6's Avatar
F350-6 F350-6 is offline
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
The metal fin kind, or the nylon strap version? I had a metal fin kind on a 95 truck. If you ever use your truck as a truck, my advice is stick with the regular tailgate. I had to fix the cable release numerous times and weld a few fins back to the edge more than once.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #4 (permalink)
Old 07-01-2009, 09:55 PM
parcs's Avatar
parcs parcs is offline
parcs is starting off with a positive reputation.
Actually, this was tested on "Mythbusters". They found the flow through tail gate to be the most efficient for mpg.
  #5 (permalink)
Old 07-01-2009, 10:02 PM
spdmpo's Avatar
spdmpo spdmpo is offline
2000 Ford F-350
spdmpo has a good reputation on FTE. spdmpo has a good reputation on FTE.
They were using a light duty pickup, I don't even think it was a half ton. Let alone a 3/4 ton CC LB. Too many variables. Even so, I wouldn't give up my tailgate for less than .5mpg. What is that, like $50/year?
__________________
Keith
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
'00 F350 CC LB 4x4 PSD - DP Live Tuning, ATS housing, 6.0 IC, Ford AIS, 4" Magnaflow, BD X-Monitor, Front leveling kit, Firestone air bags, JWVB, FRx, HPX, coolant filter, Hutch mod, ITP in-tank, Carter lift pump, CCV, Tru-cool, AIH delete, OBA, cold a/c
  #6 (permalink)
Old 07-01-2009, 11:01 PM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is online now
Have Fun...
2002 Ford F-350
Ponyboychris has a great reputation on FTE. Ponyboychris has a great reputation on FTE. Ponyboychris has a great reputation on FTE. Ponyboychris has a great reputation on FTE. Ponyboychris has a great reputation on FTE. Ponyboychris has a great reputation on FTE.
I leave my flow-thru tailgate on in the summer time since it's the 5th wheel loading type.
__________________
Chris
2002 F350 XLT, 7.3L CC 4x4, LWB, SRW, Autometer Ultralites, DP TUNER, BTS Trans, 6.0 tranny cooler, AIS w/zoodad, Warn Hubs, 4" MBRP exhaust, '08 rear end cover, Foil Delete, Heated Tow Mirrors, AIH Delete, Homemade CCV mod., Bilsteins.
The Silver Bullitt PAA# 24
  #7 (permalink)
Old 07-03-2009, 03:23 PM
Automator's Avatar
My testing showed an average of 0.3 mpg increase. I drive the same road every day, about 100 miles round trip.
__________________
-Dave
  #8 (permalink)
Old 07-03-2009, 06:04 PM
ernesteugene's Avatar
ernesteugene ernesteugene is offline
ernesteugene has a good reputation on FTE. ernesteugene has a good reputation on FTE. ernesteugene has a good reputation on FTE.
Quote:
That sounds about right to me. Trailer Life did some testing using the V shaped tailgates that don't need to be lowered for hooking up to a 5er and they saw a slight improvement in MPG. On the other hand I recall another other test that claimed a raised tailgate was better than a lowered one and it was claimed that if there's no cross wind certain road speeds result in a stable bubble of air forming in an empty bed that acts like a tonneau cover and provides less drag than with the tailgate lowered but no tests were done with the tailgate removed.
You also save some weight with the tailgate removed or replaced with a lighter substitute and this saves some fuel every you accelerate up to speed!
__________________
2005 Freightliner ext cab M2 Mountain Master RV Puller, CAT C7 300 HP, 6 speed Allison TRV3000, air locker 4.33 diff, Michelin 255/80R22.5 LRG tires, pulling a 2008 40' triple axle HitchHiker.
  #9 (permalink)
Old 07-03-2009, 07:15 PM
Automator's Avatar
Another factor, with my SRW open and the tailgate installed, I get significant air flow up through the cab and out the drivers window. With the tailgate removed, there is only a slight breeze.
__________________
-Dave
  #10 (permalink)
Old 07-03-2009, 11:50 PM
F350-6's Avatar
Slow Typing
That would probably be because an open back window would disrupt the mentioned air bubble that forms in the bed which helps airflow over the tailgate. If you drive often with the back window open, the flow through tailgate might be of some use.
Tape some string to the frong of your bed across the rail that's about 12" long and experiment with the back window open, closed, and with the tailgate removed. You 'll be able to see what the air is doing in each situation.
__________________
Chris
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
