Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 07:33 PM
24Redhorse 24Redhorse is offline
24Redhorse is starting off with a positive reputation.
AC display does not turn on!?
Ok well it has done it to me too many times. Of course this only happens when it is hot outside but it seems that when I drive for a little bit then shut off the truck for only a few minutes the complete AC dash display doesn't even light up at all. After a few hours or a few starts it kicks on like nothing has happened. It has zero power to the unit. I talked to the dealer about this about a year ago the first time it happened and he knew what it was and said it was $400 to fix it. I was wondering if this has happened to anyone here.
Since the AC went out on my car last week as well as my house. I am broke this week as those other items cost me $2,000. If it's $400 at the dealer I am sure it is a $100 part with some labor added to it.
Any help would be appreciated.
  #2 (permalink)
Old 07-10-2009, 10:58 AM
And still no responses. Nobody has ever had this problem before?
  #3 (permalink)
Old 07-11-2009, 07:12 AM
torkum's Avatar
torkum torkum is offline
1997-2003 Restoration
torkum is gaining momentum as a positive member of FTE.
What year do you have? Have you run the diagnostic self test on the unit?
__________________
2003 SUPERCREW 4X4
Tim
My PICS:
http://www.supermotors.net/registry/18031
  #4 (permalink)
Old 07-12-2009, 01:21 PM
I have a 2005 f-250, 6.0 4x4 with an automatic.
  #5 (permalink)
Old 07-15-2009, 12:00 AM
Headviking's Avatar
Headviking Headviking is offline
Headviking is starting off with a positive reputation.
The same thing has happened to me twice. Someone here told me this is not a new issue with the climate control. To get the display and the a/c back and working, cycle the headlight switch. I'm not sure if it was with the truck running or off. But try both of these procedures.
__________________
2007 Diesel-F250 4X4 Lariet CCLong Box
-COLOR="red"]Toyo A/T 285/75 18-Bilstein HD-DieselSite Coolant bypass Filter -Autotruck Toys dual steering stabilizer -Quick motor oil dain plug,
-High idle control -Reverse lights-Rotella 5w40-24" wiper blades -Interior light shut off switch
  #6 (permalink)
Old 07-20-2009, 12:29 AM
Of course now it doesn't act up since I ask the question. For some reason its seems like a voltage issue. Ever since that last little episode now my A/C acts like it is on Auto mode and spins the fan real high up for as short as 1 second and as long as 30 seconds. Is this a related issue or a whole new set of problems?
  #7 (permalink)
Old 08-10-2009, 09:21 PM
hrkdrivr hrkdrivr is offline
hrkdrivr is starting off with a positive reputation.
I have an '04 Excursion w/the 6.0 PSD. This happened to me about 5 times while it was still under (extended) warranty. Never would replicate at the shop. Finally it happened when I was driving around on a hot day so I went straight to the shop, left the truck idling and grabbed a tech. He came out, looked at the dead panel and said, "yep, you need a new panel."
The panel itself was almost $500, then they had to reprogram something because the external temp sensor said it was 20* F outside in the summer in NC.
Anyway, not a cheap part, but it was an easy install. The only thing you prolly can't do yourself is reprogramming.
  #8 (permalink)
Old 08-15-2009, 12:55 AM
bergermister bergermister is offline
bergermister is starting off with a positive reputation.
I have the exact same problem with my 2005 F350 Lariat. It has the Auto climate control and the fan goes nuts sometimes or the whole display goes dead. And it seems to only happen in the summer (its been doing this for a couple years now). If you get the proplem solved, I would apprieciate it if you could Email Me at "b.berger@shaw.ca", thanks and good luck
  #9 (permalink)
Old 08-28-2009, 08:12 PM
OK it finally did it again and cycling the headlights did the job. I think it took three cycles while the truck was running and it kicked right on. Hope this helps. Now my fan speed is still all over the place but I can live with that.
Tags
250 , 55 , ac , air , climate , conditioner , conditioning , control , display , ford , house , light , problem , truck , truth , turn , turning , working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
