Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 07:14 PM
Johnnyboy1979 Johnnyboy1979 is offline
Johnnyboy1979 is starting off with a positive reputation.
f150 power windows
Ok. I've finally had it with the drivers side window not going down. I,m going to bypass the GEM. I have already done it by connecting a jumper wire from pin 30 of the one touch down relay socket to the switch T/LBL wire. This makes the circuit indentical to the passenger side circuit just with no one touch function. My question is does any body recall where the T/LBL wire goes so I can tap it inside the cab. I assume it goes to one of the bulkhead connectors on the fuse box but not sure. Thanks
  #2 (permalink)
Old 07-02-2009, 10:45 AM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KY KR lover
2002 Ford F-150
KingRanchMan02 is gaining momentum as a positive member of FTE. KingRanchMan02 is gaining momentum as a positive member of FTE.
It goes directly from the window switch to the GEM under the dash. The GEM is on the back side of the fuse panel under the dash. Good luck!
__________________
John, aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege, 5.4L 3.55 LS, 4x2, Diablosport Predator Programmer, K&N filter.
FTE Ride of The Week, 4/20/09 !!!
`08 Mercury Sable Premier, 3.5L Duratec, 6 speed auto
  #3 (permalink)
Old 07-02-2009, 12:27 PM
All fixed. Found the wire it is in the first bulkhead connector on the fuse box, didn't even have to pull the box out to get to it. I normally don't like doing things this way, but I don't have any of the other weird problems yet .(key word) So I figured I would bypass this "gem" as they term it for now and see what happens. Window works like a charm now. Thanks for the info KingRanchmen!!!!!!!!!!!!!
Tags
150 , 1997 , 2004 , 9703 , 99 , bypass , circuit , f150 , ford , power , recall , regular , relay , touch , window , windows , working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
