Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 07:06 PM
gcooper8 gcooper8 is offline
gcooper8 is starting off with a positive reputation.
Tachometer Problem
Greetings, I have a '97 Ranger Super, XLT 4x4, auto tranny with 4.0L engine and 140k. Recently it seems the tach has taken up retirement like me and only works part-time. Usually at higher RPMs it registers something, but idling the needle will drop down to "0."
I have not been able to find info about this in my Haynes manual. Can someone tell me where to look for the sensor that reads RPM? Or is it more likely the gauge in the instrument cluster?
How can I fix this?
Thanks,
geo
  #2 (permalink)
Old 07-02-2009, 11:34 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all
Sounds like a gauge problem.
On your '97, the tach gauge receives the tach signal directly from the PCM. I think it's reasonable to assume that the tach signal circuit is good up to and including the PCM, otherwise you would be experiencing other symptoms and/or trouble codes would be set.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #3 (permalink)
Old 07-02-2009, 02:02 PM
Thanks. How would I solve the problem with the gauge itself?
I do have DTC P0443 but did not think that would be related to the Tach. What codes might occur if it is something other than the gauge?
I haven't solved the problem of the P0443 yet either.
geo
  #4 (permalink)
Old 07-02-2009, 02:29 PM
Rockledge's Avatar
P0443 - EVAP Control System Canister Purge Valve Circuit Malfunction
The PCM monitors the EVAP canister purge valve circuit for an electrical failure. The test fails when the signal moves outside the minimum or maximum allowable calibrated parameters for a specified purge duty cycle by PCM command. Possible causes:
l VPWR circuit open
l EVAP canister purge valve circuit shorted to GND
l Damaged EVAP canister purge valve
l EVAP canister purge valve circuit open
l EVAP canister purge valve circuit shorted to VPWR
l Damaged PCM
A good summary of the EVAP system in general can be found here: http://www.ford-trucks.com/forums/sh...18&postcount=3
__________________
Ford Pics
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
