Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 06:57 PM
Robert6401's Avatar
Robert6401 Robert6401 is offline
Robert6401 is starting off with a positive reputation.
Couple of questions about Bilsteins..
I can't tell by looking on the website at shockwarehouse.com which model number shocks I need. There seems to be a model for trucks with zero - 2" of lift, and another model for 3-4" of lift. I have a leveling kit that is 2.5" of lift, so which ones do I get???
Also, do the shocks come with mounting hardware, i.e. replacement bolts, nuts, washers? ---> funn story, I was changing my oil today and noticed that there was no nut and washer on the backside of one of my front shocks! I don't really know what would've happened if it had come off completely, but as crappy as these shocks are I don't think I would've noticed any difference in ride quality!
Thanks for the help. Also, will take suggestions on other places to get the shocks if there is somewhere better.
Bob
__________________
-Bob-
2003 F250 Lariat 7.3PSD CC SB FX4
Kwik (6637) Filter, RE 2.5" leveling kit, F350 Rear Blocks, TC Lock, Fumoto, EBPV/Exhaust Brake,6.0 Tranny Cooler, AIH Delete, IssPro EV2 Gauges
-Pulling a 38' Forest River Sierra 5th Wheel
  #2 (permalink)
Old 07-01-2009, 06:59 PM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
Clydes' a ^^^^^
WA.Ranger has a good reputation on FTE. WA.Ranger has a good reputation on FTE.
Don't know about what guy's are using with a level kit, but I would use the 3"-4".
__________________
http://i17.photobucket.com/albums/b93/JeffC05/th_huntingjacksonmeadow007.jpgJeff
01' CC PSD LARIAT 4X4 6" Spring Superlift, 37's
Proud Member Of The Brotherhood
WW,RRP AIH delete,RRP HRX, DPTuner, ISSPRO EV2's, TCT Tranny, HH mods, DFA RR and CCK, CCV, Tymar w Pete's Cover, DB 200A, 6.0 Intercooler, AD in #8, 5" Cannon, RedHead SG,
  #3 (permalink)
Old 07-01-2009, 07:03 PM
triskit16's Avatar
triskit16 triskit16 is offline
SEC
2000 Ford F-250
triskit16 has a very good reputation on FTE. triskit16 has a very good reputation on FTE. triskit16 has a very good reputation on FTE.
subscribing and bump...
__________________
-Tristan
2000 F-250 XLT 4x4 Ext Cab SB Auto DP Tuner 60T 80E 120R 4" Turbo Back WW F650 Dash DiPricols MAC Intake Foil Delete CCV Firestone Bags LED...
  #4 (permalink)
Old 07-01-2009, 07:06 PM
santacruzf250's Avatar
santacruzf250 santacruzf250 is offline
santacruzf250 is gaining momentum as a positive member of FTE.
If your truck doesn't leave the road, the 0-2" will be fine. If you're really stretching your stock suspension, maybe the 3-4" would be better. Either way, you'll be in a bind between extending your shock all the way and bottoming out. Those are extremes though. I'd probably go with 0-2" personally....
__________________
LOREN
2002 Regular Cab F250 4x4, 7.3L, 6SPD w/short throw shifter, 6637 w/cover, 5" Stacks, Boost & EGT Guages, DP-Tuner, Cackle Cure, HPX, AIH Delete, Foil Delete, Rear HellWig sway bar, Power Slot Rotors, 2007 Headlights, 6000K HID's, 18" XD Monsters on Nitto Dune Grapplers, and Royal Purple oil.
  #5 (permalink)
Old 07-01-2009, 08:44 PM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
1999 Ford F-250
zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of
I ask a rep at Bilstein and also at Shockwearhouse and both told me the same thing Loren just said. The valving is the same, just different range of travel. They are supposed to be coming out with a front shock made for our trucks with leveling kits. It was supposed to be out in March and is still not with no guesses as to when. I went with the 0-2 inch and have no issues, but I don't jump a lot of ditches either.
  #6 (permalink)
Old 07-01-2009, 09:13 PM
triskit16's Avatar
SEC
2000 Ford F-250
They handle decent down on the beaches, Barry?!
__________________
-Tristan
  #7 (permalink)
Old 07-01-2009, 09:14 PM
zx250's Avatar
1999 Ford F-250
Oh yeah, smooths those ruts right out. Plenty of travel for all I do.
  #8 (permalink)
Old 07-01-2009, 09:24 PM
jdecker88's Avatar
jdecker88 jdecker88 is offline
Tip Coozy
jdecker88 is a splendid one to behold jdecker88 is a splendid one to behold jdecker88 is a splendid one to behold jdecker88 is a splendid one to behold jdecker88 is a splendid one to behold jdecker88 is a splendid one to behold jdecker88 is a splendid one to behold
I got the HDs and love them though there is several people running the 5100s (3-4in ) with stock suspension.
__________________
Justin (JD)
2000 F-250 CC SB 4x4
Roadside Help NetworkDP-Tuner Guzzle's Truck Site
Pete's Custom Filter Covers Riffraff Diesel Performance
Quote:
Originally Posted by megawatt00 View Post
Kinda tough to embrace the dark side when your an electrician.
  #9 (permalink)
Old 07-01-2009, 09:26 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future
Quote:
Smae here. No problems at all.
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back Into 6" Stacks, 6637 w/,Custom Cold Air Intake ,Autometer guages, DP TUNER
http://www.roadsidehelpnetwork.info/
PAA # 14
RIP Mark.. I'll never forget you!!
  #10 (permalink)
Old 07-03-2009, 12:49 AM
DCSpecial's Avatar
DCSpecial DCSpecial is offline
DCSpecial has a great reputation on FTE. DCSpecial has a great reputation on FTE. DCSpecial has a great reputation on FTE. DCSpecial has a great reputation on FTE.
Bilstein also has a 1-3" shock.
If you have a mini spring pack you need the 0-2"
If you have a hanger and shackle you'd go with the 1-3"
__________________
DC
2001 F-350 PSD 4x4 Hell Raiser, Heavily Modified
2007 F-350 PSD 4x4 Work Horse, Moderately Modified.
Other 2wd PSDs: 99 F-450, 00 F-450, 01 F-350, 02 F-350, 02 F-550, 04 F-450, 06 F-450
  #11 (permalink)
Old 07-03-2009, 01:02 AM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
Personally, I've recently received better help with issues like this from the Tech guy at Shockwarehoue than from Bilstein. Perhaps i didn't get hooked up with the right guy at Bilstein, but the Techie at Shockwarehouse told me he's had some trouble getting solid tech help from Bilstein himself.
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
  #12 (permalink)
Old 07-03-2009, 09:38 AM
Joe_914's Avatar
Joe_914 Joe_914 is offline
Joe_914 is starting off with a positive reputation.
Smacking a shock against it's upper or lower limit will destroy it in a quick hurry.
You can use rubber bump stops (See Koni foam stops) for compression over travel.
As with anything in life the correct length is important. Shack warehouse techs are good guys.
  #13 (permalink)
Old 07-03-2009, 09:44 AM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Have Fun...
2002 Ford F-350
Ponyboychris has a great reputation on FTE. Ponyboychris has a great reputation on FTE. Ponyboychris has a great reputation on FTE. Ponyboychris has a great reputation on FTE. Ponyboychris has a great reputation on FTE. Ponyboychris has a great reputation on FTE.
You use the existing hardware from the truck to mount your new shocks so don't toss any bolts or nuts.
__________________
Chris
2002 F350 XLT, 7.3L CC 4x4, LWB, SRW, Autometer Ultralites, DP TUNER, BTS Trans, 6.0 tranny cooler, AIS w/zoodad, Warn Hubs, 4" MBRP exhaust, '08 rear end cover, Foil Delete, Heated Tow Mirrors, AIH Delete, Homemade CCV mod., Bilsteins.
The Silver Bullitt PAA# 24
  #14 (permalink)
Old 07-03-2009, 12:43 PM
fordf350crazy fordf350crazy is offline
fordf350crazy is starting off with a positive reputation.
What ones would be best suited to work with air bags? I think the bags raise the height maybe 4 inches up from stock???
__________________
Early 1999 F350 PSD: CC, longbed, 4X4. 6 spd. Mods: DP Tuner 40tow/60tow/80econ, Pilar Gauges, 6637 Air Filter, 4 inch exhaust, Late 99-03 upgraded turbo setup with an ATS 1.0 AR exhaust housing, EBPV and AIH delete, 6.0 IC, Adrenaline HPOP
  #15 (permalink)
Old 07-03-2009, 01:17 PM
spdmpo's Avatar
spdmpo spdmpo is offline
2000 Ford F-350
spdmpo has a good reputation on FTE. spdmpo has a good reputation on FTE.
That all depends on if you use the bags to lift the truck. I use my bags to keep from sagging and to maintain the original height when it's loaded, so I'm using the 0" lift shocks. I figured I would much rather have the shock go fully extended and limit a little travel rather than have it bottom out and over compress, that'll kill one in a big hurry.
It would have been nice if they made a middle of the road for the leveling kit guys, but so far no problems.
__________________
Keith
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
'00 F350 CC LB 4x4 PSD - DP Live Tuning, ATS housing, 6.0 IC, Ford AIS, 4" Magnaflow, BD X-Monitor, Front leveling kit, Firestone air bags, JWVB, FRx, HPX, coolant filter, Hutch mod, ITP in-tank, Carter lift pump, CCV, Tru-cool, AIH delete, OBA, cold a/c
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
