Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 06:37 PM
SmokeyF350 SmokeyF350 is offline
SmokeyF350 is starting off with a positive reputation.
rear speed sensor???
my rear speed sensor went bad so I was installing a new one and when i pulled it out it was broke. when it broke it let the gear in the diff or what ever that is slip off. i guess my question is are there anything else that holds this gear in its place to run beside the speed sensor?
  #2 (permalink)
Old 07-01-2009, 08:23 PM
andym's Avatar
andym andym is offline
1990 Ford Bronco
andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future
What truck is this? Most likely you're going to have to pull the cover and take a look inside. The speed sensor doesn't hold anything in place.
__________________
Andy
Quote:
Nothing is obscene if we only close our eyes
  #3 (permalink)
Old 07-01-2009, 09:22 PM
my truck is a 06 f350 crew cab, just come in from pulling cover . The speed sensor ring is just floating beside or on the big gear(cant be right) found a sheared bolt from the housing oppisite side of the big gear almost the whole thing was in the bottom .nothing looks chipped or bad what holds the speed sensor gear on?what should I do,was some scaring on the housing looks like from the worm gear? any help would be grateful. thanks scott
  #4 (permalink)
Old 07-02-2009, 12:51 AM
andym's Avatar
1990 Ford Bronco
It's definitely not supposed to be floating around. It should be bolted to the carrier in some way. I would clean the oil out, bolt the gear back on where it's supposed to go with some lock-tite and put it back together.
__________________
Andy
Tags
06 , axle , differential , f350 , ford , pull , rear , sensor , speed , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
