Go Back   Ford Truck Enthusiasts Forums > Misc. > Oil and Lubrication
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Oil and Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 06:06 PM
TC-Countryboy's Avatar
TC-Countryboy TC-Countryboy is offline
1995 Ford F-250
TC-Countryboy is starting off with a positive reputation.
F250 5.8L Oil Filter?
Hello,
I just bought a 95 F250 with a 5.8L and was looking it over and making a list of the maintainance I want to do, and noticed it didn't have a FL-1A filter that I thought was the standard . It has an adaptor on the block with oil lines going to what I suppose is an inline cooler in the lower radiator hose. At first I thought someone added the cooler, but when I looked at the owners manual, it calls out a different filter, a 820, on only the 5.8L, the 4.9 and 5.0 use the FL-1A. Has anyone else experienced this, and I was wondering if I could replace the cooler in the radiator hose with a conventional finned air cooled one? Also condidering adding a remote mount, so I could go back to the larger FL-1A filter, any thoughts on that. I have had 5 other Fords, a 94 F150 4.9, 88 Bronco 5.8L, 87 F250 4.9, 85 Bronco 5.0L, and a 94 F150 5.0L and they have all used the same filter, so I was supprised when I came across this. Any help of advise would be appreciated.
Thank you,
TC
  #2 (permalink)
Old 07-02-2009, 01:53 AM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
Yes, the FL820S is the correct filter. That cooler under the oil filter means that you have a tow package. (and one such hose cost around $80, I think)
  #3 (permalink)
Old 07-02-2009, 05:43 PM
R-WEST R-WEST is offline
R-WEST is starting off with a positive reputation.
Nothing wrong with the FL820S. It's common on the modular engines.
Now, WHY Ford did it, I have no idea - they can't seem to make up their minds what filter to use. Example - I had an '05 Freestyle with V-6 - it used the FL820S filter; got a V-6, '08 Taurus "X" last fall to replace it, IT takes the FL400S.
  #4 (permalink)
Old 07-02-2009, 06:05 PM
nflfreak43 nflfreak43 is offline
1992 Ford F-150
nflfreak43 is starting off with a positive reputation.
it changed in 94 when the block changed slightly as far as i know. i believe thats when they went to roller cam ready blocks. and 93 and before the 5.8 did take the FL1A. just think what i went through. when i got my truck i knew it had a different motor in it but i didnt know it was a 94 5.8. the previous owner said it was a 92 block. oh well. so i had to go back and buy a 820s. and also the 820s has a newer shorter design. not much of any difference though. dont worry bout it.
  #5 (permalink)
Old 07-02-2009, 10:26 PM
1995 Ford F-250
Thanks for the replies, the 820 filter doesn't bother me as much as the cooler in the radiator hose. I may still look at re-routing the oil lines to a separate cooler though and replacing the radiator hose. From what I can tell, with the oil cooler adaptor on the block, they had to use the shorter filter because of clearance issues with the crossmember.
Thanks,
TC
  #6 (permalink)
Old 07-04-2009, 04:53 PM
Freaksh0w's Avatar
Freaksh0w Freaksh0w is offline
Freaksh0w is starting off with a positive reputation.
It's still a good filter. I'd use it without any hesitation. Sure, the FL1A is quite larger, but the 820S is still the same great quality. I'd say stick with how it is.
__________________
1986 F-150 5.0 EFI XLT Lariat 4x4
NP435/NP208/9" 3.50
"Custom Exhaust" and leaf spring overloads
31x10.50 15" Nothing special, but it's a damn good truck.
  #7 (permalink)
Old 07-07-2009, 08:25 AM
Buzzard_Wing's Avatar
Buzzard_Wing Buzzard_Wing is offline
Buzzard_Wing is starting off with a positive reputation.
I would guess that the only difference between the 2 filters is the height. I don't think the FL1A will fit in the space available on an F series.
__________________
2001 SD 7.3L PSD S-Crew Long Bed
  #8 (permalink)
Old 07-07-2009, 12:50 PM
1995 Ford F-250
Thank you for all the replies, I believe I am going to trust Ford and leave the set up alone for now, and just concentrate on going through the truck and change all the fluids, and then start on some maintainance items, like u-joints and such.
Thanks,
TC
  #9 (permalink)
Old 07-07-2009, 01:30 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is offline
Milwaukee1979F150 is starting off with a positive reputation.
No wondered why it so hard to install FL1A in van that is 96 E350
First I thought I got wrong filter but know 5.8L use FL1A it got 6 mins of try screw filter fit due tight area.
is FL820S correct oil filter for 96 E350?
__________________
Sorry for my bad grammar.
79 F150 4wd 4 speed Project
91 Bronco XLT 5.0L AOD. Replace intake, heads, and exhaust then install snowplow.
Currently drive 94 geo tracker until Bronco is ready.
  #10 (permalink)
Old 07-07-2009, 02:48 PM
Freaksh0w's Avatar
When I look up a 96 E350 with the 5.8 V8 on Autozone.com, it shows that it calls for an FL1A. Take it for what it's worth.
__________________
NP435/NP208/9" 3.50
  #11 (permalink)
Old 07-07-2009, 03:39 PM
Quote:
Problem it was so tight that you couldn't tight oil filter enough without arm hit frame or steering linkage.
it have 1/2" clearance for oil filter near crossback which is bottom of oil pan that what is prevent me from change oil filter. If they could design like Ford 300 then it be so easy to change oil filter.
__________________
  #12 (permalink)
Old 07-07-2009, 04:28 PM
1995 Ford F-250
I would say most 5.8L applicatoins take the standard FL1A, but because mine has the oil cooler adaptor on it, it requires the 820 due to clearance issues. Also, I took a look at both filters the other day, and they are threaded differently. Without measuring, the FL1A appears to be 3/4", and the 820, possibly 7/8", therefore, they will not interchange. So if it says it takes the FL1A on the E350, I would say it probably does.
  #13 (permalink)
Old 07-08-2009, 09:34 AM
jimandmandy jimandmandy is offline
jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE.
The 820S has METRIC threads. Dont even think of trying to interchange them.
If you need a shorter equivalent of the FL-1A for clearance reasons, look for a 1980's Dodge Ram Van application. Our 1987 B-series with the 318 (5.2L) calls for a short version of the otherwise identical design. Funny thing, there is no clearance problem with that engine in that van and I use the long filter.
  #14 (permalink)
Old 07-08-2009, 02:31 PM
Like a Fram PH-16 & PH43/Purolator L14670 & L10017/WIX 51068 & 51085, etc... There are a pile out there that will work.
Even an FL400S (and its equivalents), which are skinnier than the FL-1A, in case the clearance problem relates to diameter of the filter. There is a slight difference in gasket size between the 400 and the FL1A but the filter gasket boss is generally wide enough that the 400 will fit without leaking.
BTW - the FL400S is a winner for Briggs/Stratton & Kohler lawnmower engines, too, but that's another matter altogether.
BTW #2 - As regards the Frams mentioned earlier, the anti-Frammers are probably jump starting their keyboards right now, but I can tell you that we've used hundreds of Frams for millions of miles, with nary an issue.
  #15 (permalink)
Old 07-08-2009, 06:59 PM
Good catch on the metric threads Jim.... I just assumed they had to shorten it to fit.
I have both on the shelf in the garage but sold my 95 5.8 recently. I got the FL1A's for the Town Car (5.0L) and can still use it on the Gravely LI. Pretty strange that a 1 cyl engine would have a bigger filter than an F-250.
__________________
Tags
2009 , 58 , 58l , 93 , change , cooler , efi , f150 , f250 , f350xl , filter , ford , l10017 , location , oil , v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
