Man/Sask Archived Buy/Sell/Trade Ads
#31
I have a add on saskatoon kijiji so I thought I would put it on hear to.
WANTED: 65-66 8 ft truck box and fenders
67-69 8 ft truck box and fenders (will look at 67-72 parts)
Any 65-79 ford trucks/parts 1/2 ton -1 ton and 4x4's
Mostly want disk brakes and power steering off 73-79 half tons
Any 4x4 parts too.
Any 4x4 parts too.
#33
I may be moving to a newer truck in the near future, if that's the case, the Crew Cab will have to go on the "For Sale" block. So... 1978 F250, Crew Cab, 4x4 NP 205, SM435, with granny first, Dana 44HP front, Dana 60 rear, 4.10s, going "as is". $5000 starting. Pics of the mods and work in my gallery. This is harder than I though it was going to be!
#34
In progress of being pulled... would include all sensors, accessories and computer... oil pan to intake.
Only catch... I'm in Canada... Winnipeg, Manitoba to be specific.
Best offer applies. Will arrange shipping if required.
thecdp@thecdp.ca or 204-226-3420
#35
on
1947 Ford Cab Over. Mostly complete but with lots of bullet holes. $1600. gets it. Located in central Saskatchewan. can e-mail more pictures. ...Stan. .................................................. .....................
#36
I decided I would like to try and turn my shortbox into a 4x4 if I can find the parts.
I am looking for a 87 and up 1/2 ton 4x4. Whole parts truck would be great, as i need the front end, tranny (looking for a 5 speed) transfer case, and most likely rear end too.
A 3/4 ton truck would work, but the truck would have to be fairly complete. Engine or body condition does not matter, as I would need just the drivetrain, and parts from teh drivetrain.
If you know of anyone that has either a 1/2 ton or 3/4 ton ford in the 87-96 era, and its a 4x4, and it has a high mileage engine, lots of rust on the body, or maybe even smashed up, let me know! If you have one, just pm me, and let me know the price your asking for it!
#38
WANTED: a hub cap to match the ones on my 77 f150 in my gallery i have 3 need a 4th to complete the set.
https://www.ford-trucks.com/user_gal...&albumid=36861
#39
Parting out:1993 Explorer Limited.SGI TL vehicle hit in the front right corner.All parts available except the transmission.Green exterior,grey leather interior,4x4,4 door,lots of options.
#40
FOR SALE:
'53 front grille, no teeth or emblems, small ding by center emblem but easily fixable. $75
'53-'56 fromt bumper, steel good shape painted gloss black $75
'53-'55 chrome headlight trim rings (2) good shape some small pits $30 for the pair
'53-'55 vaccum wipers, need cleaning but they work great $25
Flathead Parts:
2 '48-'53 8RT iron heads $30 for the pair
'48-'53 stock aluminum intake $30
'48-'53 3 3/4" crank, out of a recently rebuilt motor (would have to be checked to be sure) $50
'48-'53 stock cam, lobes appear to be in good shape, its out of the same motor as the crank $35
'48-'53 fiber timing gear, good shape $5
set of valve, valve guides, retainers, keepers and clips, all in good shape some keepers may be missing or broken (cant remember) $40 for all
oil filter cannister $15
'48-'53 fuel pump with glass bowl, needs a good cleaning $15
2 thermostat housings $10 for both
6V generator in working order $25
Generator hold down bracket $10
48-53 stock oil pressure sending unit $5
48-53 dizzy dont know anything about it, no cap or condenser $5
94 holley carb, dont know much about it but looks in ok shape, oil bath post is a little bent but can be straightend easily, probably good idea for a carb kit $50
48-53 stock ignition coil, dont know anything about it $5
2 48-53 water pumps, 3/8 belt pulley, a little rusty but a good cleaning and they should be good (new ones run $200) these are $40 for both
48-53 3 blade fan with 3/8 crank pulley, fan blades are a little bent but easily fixable $10
Misc. stuff
4 sheets 10' 1/2" dry wall $5 a sheet
1 sheet 10' 5/8" drywall $5
set of 4 Cragar S/S wheels 2- 15x8 and 2- 15x10 with rubber, chrome is peeling a little, bolt pattern is 5 on 5 1/2" $150
custom built ported mdf sub box with black felt outside, 2 10" JL W1 and a 350 Zapco amp with all rca's and fuses and power wires $200 for all
2 '92 mazda Rx7 bucket seats with belts, burgundy with lumbar adjustment and height adjustment with removable head rests $200
8" Beaver table saw, external electric motor and belt driven, works great but takes up too much room, make me an offer
Pics are available for everything just drop me a line.
** I love spring cleaning
Flathead Parts:
Misc. stuff
#42
sadly, i am gonna have to let my toy go... 1979 ford f-150 xlt lariet 4x4... lifted, big tires, lots of money dumped into this truck... but i need some funds for my hot rod build...
pictures and info here --> http://www.usedregina.com/classified-ad/9519114
#45
1977 Ford F-100, 400CI, C6 tranny, body is mint, no rust, however it did have patch panels put over the rear wheel wells and it is not a perfect job. New rims with new tires, 245/60R15 on the front and 275/60R15's on the back. Brand new 2-1/4 inch dual exhast with Cherry Bomb glasspacks, and tilt steering. Brand new JVC cd player, new speakers in the doors, two 10" Alpine type "S" subs and a Alpine V12 digital amp. $3500
photo's are here www.thunderlakeracing.ca
PROCEEDS GO TO DISABLED DRAG RACING
