Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 05:22 PM
Rob90 Rob90 is offline
Rob90 is starting off with a positive reputation.
Transmission problem
I have an 03 F350 with 95,000 miles. Its been a great truck until recently. Today I started out pulling my 5th wheel and every thing was fine. I got to an area with some hills and turned on tow/haul. A few seconds later it began to flash. I have pillar gauges and everything looked good. Trans temp was 170 and the shifts felt normal. I pulled over looked at my owners manual to see what the flashing indicated. I was in the middle of BFE and had 70 miles to the next town. So I restarted my truck to go to the next town and the light never flashed again. Trans shifted fine and temps remained normal. If I engaged tow/haul and slowed down enough for the trans to downshift I felt a shudder and the light would blink. Turn truck off then restart light would stay off until I tried to engage tow/haul. I did a search and found some info about a TFT sensor. Could it be that and how serious is the problem because this is my only vehicle and will have to travel to get to a dealer.
Thanks in advance
  #2 (permalink)
Old 07-01-2009, 06:39 PM
ljutic ss's Avatar
ljutic ss ljutic ss is offline
2003 Ford F-250
ljutic ss is gaining momentum as a positive member of FTE.
Several months ago I had to replace the TFT sensor because it became defected and was showing the trans oil as very hot. Typical flashing tow/haul light. Could be yours is on it's way out.
  #3 (permalink)
Old 07-01-2009, 09:53 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Former Ford AutoTrans Eng
Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold
There are at least 50 different reasons why the tow/haul would flash. The ONLY way to know why is to have the codes read. You need to have a very specific tool to be able to read Ford transmission codes. Anywhere that will read codes free won't have this tool.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #4 (permalink)
Old 07-03-2009, 08:32 PM
Pulled codes.
P0730 Incorrect gear ratio
P2700 Transmission friction element A Apply time range/Performance
  #5 (permalink)
Old 07-03-2009, 08:35 PM
bismic's Avatar
bismic bismic is online now
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
What is the maintenance history? Was the tranny fluid changed (or flushed) every 30k? Was only Mercon SP fluid used? how about the change frequency on the external filter?
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
  #6 (permalink)
Old 07-03-2009, 08:40 PM
All fluid was flushed and inline filter was changed at 70,000 when I got the truck. I just hit 95,000. Maint before that I have no Idea. Trucks been great up until the last 2 weeks. IPS sensor, ALT, and now the flashing tow/Haul light
  #7 (permalink)
Old 07-03-2009, 08:42 PM
bismic's Avatar
Mercon SP?
__________________
Mark
  #8 (permalink)
Old 07-03-2009, 08:46 PM
Yes Mercon SP i was going back to edit that. Been looking at the tech folder and see the codes listed but have no Idea what to make of it. Is this something bad taht I will not be able to drive to my dealer 80 miles away
TorqShift Gear Trouble Codes:
When diagnosing a TorqShift transmission, trouble code P0700 may be stored. Diagnose using any additional stored codes. P0730 may be found stored with codes P2700-2704. Use the additional code(s) to determine which clutch or clutch control is causing the gear ratio P0730 code to be set. Broadcast Message 1158, 1525.
  #9 (permalink)
Old 07-03-2009, 09:06 PM
Do you think my ALT going south along with my batteries could have caused this. It did the typical thing where one by one things quit working until I was stranded on the side of the road. Batt light never came on to give me a warning. Alt was only 6 months old as were the batteries
  #10 (permalink)
Old 07-03-2009, 09:37 PM
Greg B Greg B is offline
Greg B is starting off with a positive reputation.
Batteries going bad do make these OBD-II PCM's do weird things. You can try clearing codes and see what happens. If there is a problem, it won't take long for the codes to return. It's possible that there could be other problems. Earlier 6.0's had chafing problems on some of the harnesses that ran under the intake. If something were shorted to ground, it wouldn't take long to kill an alternator and batteries.
  #11 (permalink)
Old 07-03-2009, 09:48 PM
I cleared the codes and they came back. Just was wondering if the low voltage condition could of caused a sensor to go bad
  #12 (permalink)
Old 07-03-2009, 09:57 PM
bismic's Avatar
Low voltage can cause FICM failure but I have never heard of it causing a sensor failure. Maybe Mark K will jump in again for you.
__________________
Mark
  #13 (permalink)
Old 07-03-2009, 10:28 PM
The light will never flash unless I engage Tow/Haul. Drove to the fire house for work and it preformed great. Shifts good and no light. One of the pluses to working 24 hours is that you have free time for the Internet and working on vehicles. My big concern is the 80 mile drive to the dealer
  #14 (permalink)
Old 07-04-2009, 08:37 AM
If it only flashes with the tow/haul on, don't turn on the tow/haul going to the dealer.
Low voltage won't hurt any of the sensors. They are working right, as shown by the codes. It's showing that one of the clutches (I forget which one is A - we didn't use those designations in Engineering) isn't applying correctly. That's usually a mechanical problem, though it could be a sticky solenoid.
__________________
Mark
  #15 (permalink)
Old 07-13-2009, 05:30 PM
Thanks for the info guys. The trucks at the shop but I have one more question. I call the shop and they inform me they are out road testing the truck. 30 minutes latter I get a call that says I need a new trans. 1st 2nd and 3rd gear clutches are bad including the solenoid. My question is how are you able to make this DX without dropping the pan. The trans Temps have always been normal and have had no indication of slipping. Can you tell all this from codes or do I need a second opinion
Tags
blinking , f350 , haul , light , tow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
