Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 04:45 PM
rog2867 rog2867 is offline
rog2867 is starting off with a positive reputation.
Front Wheel smoking
I just stopped at at traffic light and smoke was rising up from the front right tire.. When I got home I looked at it, couldn't see anything obvious but the smoke was definately coming from the wheel and it smelled like burning. Any ideas what it could be?
roger
  #2 (permalink)
Old 07-01-2009, 07:42 PM
alloro alloro is offline
alloro is gaining momentum as a positive member of FTE.
Assuming it wasn't steam from driving through a puddle...the caliper could be frozen and not releasing pressure on the brake pads.
__________________
If you like the advice you get, be sure and click the left red "Add to Reputation" button
to the right of the word "permalink" at the top right of the poster's message window.
  #3 (permalink)
Old 07-01-2009, 09:21 PM
bnovak bnovak is offline
bnovak is starting off with a positive reputation.
X2 on the brake caliper being frozen. Although, you may find that it's the opposite side that's actually frozen up. This will cause the working side to work that much harder, and overheat.
Check them both and let us know.
  #4 (permalink)
Old 07-02-2009, 05:42 AM
broncoholic's Avatar
broncoholic broncoholic is offline
broncoholic is starting off with a positive reputation.
If you have a frozen caliper, the truck should be pull towards the smoking wheel. If it pulls while driving, then the smoking wheel caliper is stuck in the braking position. If it pulls while braking, then the opposite caliper is stuck in the non-braking position and the smoking wheel caliper is being overworker and overheating. If it's not a caliper, look for a bad hub seal puking grease that's burning off.
__________________
03 Expedition EB 78 Bronco Custom
  #5 (permalink)
Old 07-02-2009, 08:48 AM
thanks for the suggestions. I was thinking something along those lines also. I also noticed that the breaks were not very responsive as they usually are. I had to push the pedal to the floor which never happens.
  #6 (permalink)
Old 07-02-2009, 11:27 AM
so it is the caliper stuck. The hydrolic line is gone, the rotor is no good and the pads are gone. Mechanic is trying to look for the hydrolic line now, seems its only available from ford and no one has it and everyone is closed for the holiday weekend. Might have to wait till Monday. Looking like 500 to fix plus tax.
roger
  #7 (permalink)
Old 07-02-2009, 04:40 PM
Go to autozone. They've got the hoses ($15) rotor ($35) calipers ($65) and pads are about $30.
Other than bleeding the brakes, the job is pretty straightforward.
Tags
caliper , front , smoking , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
