Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 04:33 PM
LDB907 LDB907 is offline
LDB907 is starting off with a positive reputation.
will not shift into 1st or 2nd gear
I have a 1997 F150 manual 5 speed transmission. When I put it in 1st or 2nd gear my truck will not move, but it will work in the other gears. Can anyone help me with this problem? I would also appreciate knowing where I can find a diagram of the shifting mechanism. Thanks for your time.
  #2 (permalink)
Old 07-01-2009, 05:15 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KY KR lover
2002 Ford F-150
KingRanchMan02 is gaining momentum as a positive member of FTE. KingRanchMan02 is gaining momentum as a positive member of FTE.
Welcome to FTE LDB907! The shifter goes directly into the top of the transmission. You have bushing in the shifter that are worn out that are causing two gears at one to be engaged, The bushings will have to be replaced. Good luck!
__________________
John, aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege, 5.4L 3.55 LS, 4x2, Diablosport Predator Programmer, K&N filter.
FTE Ride of The Week, 4/20/09 !!!
`08 Mercury Sable Premier, 3.5L Duratec, 6 speed auto
  #3 (permalink)
Old 07-01-2009, 10:26 PM
Thanks for the information KingRanchMan02. I am going to try to get the bushings at the parts store, and if they don't have them then I will go to the Ford garage. I'll let you know how it goes when the job is done.
LDB907
  #4 (permalink)
Old 07-16-2009, 02:55 PM
Didn't work
KingRanchMan02, thanks for the idea but I put new bushings in and it didn't work. Do you have any other ideas?
Thanks.
LDB907
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
