Where does this Vacumm line go
As far as I know, that's a vacuum distribution block mounted up behind the AC hose. The larger line is vacuum source from the engine. It should be connected to the vacuum fitting on the intake manifold.The small line is the vacuum source to the Heating/AC system. The square box that the small line is running to is a vacuum reservois for the Heater/AC system.
That did it.. I couldnt see behind there so I followed the Brake booster line and kinda felt around and found what felt to be where the line went... Right size and everything.. Line went on great..
Must have knocked it off without realizing when I pulled the Upper Intake off while replacing the Injectors... Now time to wait for my stupid ECM to get rid of these 2 (Mainly 1) ghost trouble codes (Error 41 and 56) all wires checked out Ok and still happens when forcing the truck to run rich.
Thanks again
James
Thanks again
James
