You can do under drive pulley's they are a for sure thing. I have dyno results before and after they where worth 20hp and 54tq. Bump the timing, cut the air horns out, and lose the factory exhaust. Do not add a bigger TB and a bunch of air to it the factory SD can't handle it.
__________________
1996 F-250 XLT 460 Super Cab 4x4 4 inch lift 33x12.5 Tarra Grappler's on Pacer alloy's. Rebuilt motor, comp cam, ported heads and intake, hedman headers, wide band AFR, mass air and anderson PMS
1986 stang 351W, TFW heads, big roller cam, TKO 600 tranny + 7 yrs of my life and every pay check.
