Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 03:38 PM
mr.auto mr.auto is offline
mr.auto is starting off with a positive reputation.
bed options
anyone on here make a flat bed for there1st gen ranger? i got a 89 with a rust issure in the bed and i am gonna use it for my mowing biz so im looking for ideas on flat bed options, or other options, thx guys
  #2 (permalink)
Old 07-03-2009, 12:39 AM
racsan's Avatar
racsan racsan is offline
1993 Ford Ranger
racsan is starting off with a positive reputation.
check your rear spring hangers& brackets. if your bed is bad enough to toss for a flatbed, those are probly gone too. ive seen a s10 extended cab recently that someone made a flatbed for, they extended the frame as well and it has a 7' or 8' ft flatbed.
__________________
'93 Ranger Supercab,4.0L,4x4 5spd-hurst equipped. mile marker manual hubs. "the green machine" http://www.myspace.com/small_dog_trucking
http://www.cardomain.com/ride/3216869
  #3 (permalink)
Old 07-09-2009, 03:50 PM
everything else is fine, the bed is just rusted and dented all to hell lol
  #4 (permalink)
Old 07-10-2009, 08:59 PM
michigan66 michigan66 is offline
michigan66 is starting off with a positive reputation.
Lay 4 treated 4 x 4's across the frame, evenly spaced as possible, 2 ahead of the frame hump over the axle and 2 behind. Bolt 5/4 treated boards lengthwise to the 4 x 4's. Bolt a piece of galvanized angle iron to the back end to protect the ends of the boards. I'd suggest using galvanized carriage bolts throughout. Mount aftermarket tail/turn lights (LED lights would look great) and wire them up. Let the boards cure out and coat the floor with spar varnish. You can build up the sides if you want to keep your equipment from falling off or mount tie down hooks on the ends of the 4 x 4's to strap down your equipment. You may also want to build a front head board to keep stuff from banging against the back of the cab.
Good luck.
__________________
1991 XLT, 2.3 SOHC, M5OD manual, 3.45 7.5" axle
Valvoline Synthetics in Trans., Diff.;
Motorcraft Blend in Engine
225/70 x 14 Bridgestone Dueler APT III tires,
90 K miles., std. cab, long bed, fiberglass topper
  #5 (permalink)
Old 07-11-2009, 06:00 PM
thx man for the help
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
