Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 02:18 PM
RAMBOv10 RAMBOv10 is offline
RAMBOv10 is starting off with a positive reputation.
What year 4.6 will work
My brothers truck 1997 4x4 f-150 super cab 4.6 with 120,000 miles has little or no compression on cyl 2. I am going to pull the motor and remove the head to see what is wrong. It has the romeo engine in it now but if the engine is too far gone will any other 4.6 engines work? Thanks for any help.
__________________
Daniel
2003 F-250 V10 Sport CC 4X4 Long Bed
  #2 (permalink)
Old 07-01-2009, 03:03 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KY KR lover
2002 Ford F-150
KingRanchMan02 is gaining momentum as a positive member of FTE. KingRanchMan02 is gaining momentum as a positive member of FTE.
Any 4.6 will work. There is a difference in the flex plate for the transmission because of a difference in the number of bolts at the crankshaft. Just use the flex plate from the particular 4.6 and you should be good to go. Good luck!
__________________
John, aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege, 5.4L 3.55 LS, 4x2, Diablosport Predator Programmer, K&N filter.
FTE Ride of The Week, 4/20/09 !!!
`08 Mercury Sable Premier, 3.5L Duratec, 6 speed auto
  #3 (permalink)
Old 07-01-2009, 09:00 PM
Got the motor out today, tomorrow I will take it apart and see how much damge is done.
Thanks for the reply
__________________
Daniel
  #4 (permalink)
Old 07-02-2009, 10:47 AM
KY KR lover
2002 Ford F-150
Hopefully it is nothing major. Good luck!
__________________
  #5 (permalink)
Old 07-02-2009, 11:54 PM
Well, got the head off today. The intake valve was not seating. I checked the valve spring and cam and everything looks fine. I found out he had replaced that plug with the wrong one. I am guessing that is what caused the valve to mess up. He is going to check around and see which is cheaper...to replace the engine or repair this one.
__________________
Daniel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
