Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 01:53 PM
kittyhawksurf's Avatar
kittyhawksurf kittyhawksurf is offline
kittyhawksurf is starting off with a positive reputation.
How much should I pay for replacing front hub?
I just found out my other hub went bad on my passenger side which left me stuck on the beach again 'cause I couldn't engage 4 wd.
How much should I pay for the hub replacement? I have new locking hubs, so I guess just how much should I pay for the interior replacement.
My current quote is $550. It seems so expensive.
__________________
Most of man's problems come from the inability to remain still.
  #2 (permalink)
Old 07-01-2009, 02:41 PM
12ozd 12ozd is offline
mmmmm...beeer
12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE.
I'll do them all day long for $550.00!
Are you talking about replacing / converting to manual hubs ?
Do it yourself !!
Won't take any time at all and very easy to do.
http://www.ford-trucks.com/forums/46...-complete.html
  #3 (permalink)
Old 07-01-2009, 03:16 PM
I just got new locking hubs on it, but I am talking about the interior part. The part where the nuckle goes into the hub. The nuckle is loose just like it was on the other side when I had to replace it. I may not be using the correct terminology. i will try to go look at the link that the guys here diagnosed the problem the first time.
The reason I am probably not doing it myself is because I don't have the tools to do it. I don't even have a jack or jackstand that will work with this truck.
__________________
  #4 (permalink)
Old 07-01-2009, 03:26 PM
__________________
  #5 (permalink)
Old 07-01-2009, 03:28 PM
mmmmm...beeer
Gotcha, thats gonna be a little more $.
(what did the other side cost? should be the same)
Can you do the job? (got a bfh?)
If you can take the brakes & rotor off you're only 4 bolts away from removing the hub.
  #6 (permalink)
Old 07-01-2009, 03:29 PM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
Man that wobbles pretty bad. That part you were moving is not the hubs. The hubs are the part you lock and unlock to go into 4wd. I'm no expert on it but it looks to me like the bearings are completely shot.
  #7 (permalink)
Old 07-01-2009, 03:33 PM
Yea, I just did the other side and it was about the same cost. I had to replace the axles to though which ended up being $1300.
What is a BFH?
I def am competent enough to remove brakes and rotor, but I am not sure if I got the tools. Even the jack and jackstand as I edited into my previous post 3 up.
__________________
  #8 (permalink)
Old 07-01-2009, 03:38 PM
mmmmm...beeer
Quote:
Originally Posted by kittyhawksurf View Post
What is a BFH
Big hammer
  #9 (permalink)
Old 07-01-2009, 04:00 PM
Quote:
That was actually triskit's video. He was one of the guys that helped me diagnose the problem on the driver side.
When you get under the truck the nuckle is not solidly attached. It can move about.
From what I understand the hub assemblies are all one piece on models after 1999. That obviously is not talking about the locking mechanism.
They replaced my warn hubs without replacing the hub assembly...?
__________________
  #10 (permalink)
Old 07-01-2009, 04:06 PM
Ford79's Avatar
Ford79 Ford79 is offline
2001 Ford F-350
Ford79 has a good reputation on FTE. Ford79 has a good reputation on FTE. Ford79 has a good reputation on FTE.
If you need the hub/bearing assembly, try here http://www.trademotion.com/partlocat...?siteid=214072
Ed should be able to beat that price.
__________________
Mike
2001 F350 CC LB 7.3 with a few mods
Wisconsin Chapter Leader JOIN HERE
7.3 Roadside Help Network
  #11 (permalink)
Old 07-01-2009, 04:13 PM
Yea, someone posted that in my "just plain embarassing" thread. I am just not sure exactly what I need. Regardless it looks like his hub assemblies are about $300.
__________________
  #12 (permalink)
Old 07-02-2009, 01:36 PM
I found the hub at http://www.partsgeek.com for only $182!!!
__________________
  #13 (permalink)
Old 07-02-2009, 03:08 PM
mmmmm...beeer
Just my .02, Those are FEQ hubs. Do yourself a favor and look into them before you spend your hard earned money.
There is a reason they are alot cheaper.
(made in china junk)
(did you try Ed the parts guy?)
  #14 (permalink)
Old 07-02-2009, 09:11 PM
suzuki0702's Avatar
suzuki0702 suzuki0702 is offline
suzuki0702 is starting off with a positive reputation.
ive got a autozone hub due to it being seized on the axle (after only 35k) but i picked it up for 260 i think and the truck is at 73k and its working just as it should
__________________
2004 F250 CrewCab, FX4 Off-road, 5.4, 3.73, K&N FIPK, IMCO dual 3" performance exhaust, Jensen 7" TFT flipout touchscreen
  #15 (permalink)
Old 07-02-2009, 11:00 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
Some on Ebay
Tags
2005 , balljonts , brg , explorer , ford , labor , replacement , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
