Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 07-05-2009, 10:08 AM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by ironmine View Post
Hi Greg ... I understand what you are saying (and bb's , when properly working, have a slight positive pressure). But, your method sure is better than nothing.
my 2 cents
Actually it's a very good idea. I have a post w/pics on it somewhere in here. When I loaded the first one up it forced a little water out also. They each took a whole mini-tube of grease and I'm sure they never had that much in there before. It doesn't come out and get on the rotor either. Just my 9 cents (inflation).
  #32 (permalink)
Old 07-05-2009, 10:16 AM
EXv10's Avatar
Quote:
Originally Posted by Greg B View Post
The wheel bearings are what I was referring about force. If you stand with both feet together you are knocked off your feet much easier than if your feet are spead about shoulder width apart. It's a law of physics. The same applies to front wheel bearings. They are able to withstand more force if they are spread apart as they are in the older trucks than if they are back to back like in the newer trucks. If you understand the principle of leverage then you understand what I'm talking about. That's why I refer to the wheel bearings as being a weakness on these trucks. As for ball joints, it's just the nature of the beast. As heavy as these trucks are it would be difficult to design one that would last longer. It doesn't seem to matter whether they're greasable or not.
I understand but I think that was the intention of the needle bearings. They take the load on the turns and the other bigger ones support staight line driving which is +-90% of the time. Do you know what they are? Double or single row rollers? A ball bearing?
  #33 (permalink)
Old 07-05-2009, 10:41 AM
Chris1450 Chris1450 is offline
Chris1450 is starting off with a positive reputation.
Ok.. a little correction here. This isn't Ford's design as far as the front bearing assembly. GM and dudge also use the same design because they also use dana axles. A freind at work is going thru this same problem on his dudge. He is into it over $1100 now. If I heard him correctly, the part numbers are even the same for the bearings on the other makes.
  #34 (permalink)
Old 07-05-2009, 11:33 AM
EXv10's Avatar
I don't think it is the bearings fault, I think it is the inability of being able to grease them. I say it is well worth it to pack them through the ABS hole or drill a hole and add a zerk. I have a post on it in here somewhere. After i did my inner and outer hubs all my little binding, clunking, and disengaging problems were gone. My hubs are happy now.
  #35 (permalink)
Old 07-05-2009, 12:07 PM
wolffee's Avatar
wolffee wolffee is offline
wolffee is starting off with a positive reputation.
EXv10,
You seem to have some good insight around here. You were the first to respond to me a few days ago. I have been out of town but back now and more confused then before. I know its not rocket science but I am not getting it. Probably because I havent had it apart yet to see it for myself and seems to be different people are using different terms for different things. Hope you can forgive me. When I have the locking device(hub?) first thing to come off. Manual and lock switch came off with just pliers on snap ring. When I get that off axle shaft is there. I can push up and down on it and it moves opposite up and down right as its coming out of the axle tube as well. So there is movement in two places. inside the knuckle? correct term? and the actual axle as well. so two places from as much as I can see. I guess i need to know exactly what I need to replace before I pull it apart as i cant do the job here at the house. I had to go back to school after being laid off and getting a degree in heavy diesel engines. Over the road and big marine. MTU's Detroits that kinda thing so I am mechanical and have access to a huge shop every toy in the world. Want to know what I need in advance as school is over an hour away and need to drive the truck home at the end of the day. Dont want to get it apart and find im missing pieces.. Already have new Moog joints ready to go in. Just need the bearings? for axle? and what ever I need for the knuckle? is that the hub assembly? the Timken515020. I am familiar with Timken we use all their bearings in our over the road tucks and trust them so thats cool if I can use it on my truck as well. feel confident. if you or any could just break it down like you are going to need this .... this.... and this... going to have both sides apart so going to wanna doing the fix on both sides. so part#s great any help would be greatly appreciated. Sorry its long but needed to get all points across so you guys could have all info... appreciate having this site for people who need help
thanks alot
Ryan
__________________
2004 F-350 King Ranch 4x4 6.0 SRW SWB CC.
2.5in Leaf Spring Lift in Front.5in blocks in rear. Moto Metal 20x10's 305 55R20's. Fabtech Traction Bars. Fumoto Valve. SCT Tunner. Train Horns. Upgraded Compressors and big tank to run air tools. CB Radio. Rancho 9ks. Amsoil Oil ByPass System
  #36 (permalink)
Old 07-05-2009, 04:32 PM
Greg B Greg B is offline
Greg B is starting off with a positive reputation.
Ryan
If you just want to do an original equipment replacement, then I would go with the Timken replacement hub and bearing assembly for the quickest and least expensive way to get it on the road. Wheel bearings on these rigs can last as long as 100,000+ miles or as little as 50,000 miles dependind on loads, type of roads driven on, and so forth. The Dyna-Trac retro kit that I referred to in earlier posts completely converts the front wheel bearing design to the same as the 97 and older trucks which is stronger and more serviceable. In fact, according to the 97 shop manuals the wheel bearings are supposed to be cleaned and repacked at a 30,000 to 60,000 mile interval with new seals installed. That is the most bullit proof bearing set up for these trucks. Dyna-Trac also makes the retro kits for GM and Dodge 3/4 ton and heavier trucks. If they made one for the F150's I'd be looking into one.
  #37 (permalink)
Old 07-05-2009, 08:20 PM
jeffdoerr jeffdoerr is offline
jeffdoerr is starting off with a positive reputation.
Wheel bearing and hub assembly on ebay for around $100. They are chinese, but work ok for light duty stuff. Really easy to change, probly a 2 hour project at most. The worst part is replacing the vac seals ($30) And make sure you get a new oring for the hub assembly.
American made bearing will run about $350, get the seals too, either dealer or REAL autoparts stores (Napa, car quest, etc)
__________________
00 F-350 Lariat 7.3 CC LB 4x4 3.73 l/s, 275k, pop-up GN hitch, 6637, foil delete, BD X-monitor, DP Tuner decel/40/80/140/drive-thru
99 F250 Lariat v10, ext cab, bone stock 285k miles, boss v-plow
99 F250 XLT 7.3 6spd 4x4 6637, DP tuner 40/80/120, 5 in exhaust 345k miles
  #38 (permalink)
Old 07-05-2009, 08:34 PM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
Clydes' a ^^^^^
WA.Ranger has a good reputation on FTE. WA.Ranger has a good reputation on FTE.
You can buy a brand new TIMKEN with ABS sensor for less than that.
List Price: $263.37
Price: $234.22 & this item ships for FREE with Super Saver Shipping. Details
You Save: $29.15 (11%)
Usually ships within 2 to 3 days.
Ships from and sold by Amazon.com.
__________________
http://i17.photobucket.com/albums/b93/JeffC05/th_huntingjacksonmeadow007.jpgJeff
01' CC PSD LARIAT 4X4 6" Spring Superlift, 37's
Proud Member Of The Brotherhood
WW,RRP AIH delete,RRP HRX, DPTuner, ISSPRO EV2's, TCT Tranny, HH mods, DFA RR and CCK, CCV, Tymar w Pete's Cover, DB 200A, 6.0 Intercooler, AD in #8, 5" Cannon, RedHead SG,
  #39 (permalink)
Old 07-05-2009, 08:37 PM
ironmine ironmine is offline
ironmine is starting off with a positive reputation.
The Dana 60 is a series of axles with many applications, including custom, and has various axle end configurations, even methods of lubrication. My contention was that it was not a failure of Ford's required spec's to Dana, Dana's manufacture of the hub, or even the special grease. But, in the oe's zeal to reduce pm, etc ... the sealing of the hub unit was compromised. Really , it seems to me, something that needed real world testing ---- that couldn't be completely worked out at the engineers' desk. Just my opinion.
During June, I bought hub assy's for my sons' friends, to do their trucks ... a Ford and a Dodge. '02 3/4ton 4wd. I'm pretty certain that they were different part numbers, with different prices. From NAPA. I even got prices from DynaTrac on their FreeSpin upgrade kits for the trucks, because the boys were interested in going to a standard spindle set up to do away with failed bearings. And those part numbers were different. I don't know ... maybe the numbers cross back into each other, etc
I think the only reason for the needle bearing is to reduce friction between the rotating hub and the shaft.
  #40 (permalink)
Old 07-05-2009, 09:41 PM
wolffee's Avatar
OK I am down with the Timkin needle bearing replacement and see how it is one piece lug post and all ABS sensor, cant buy just the bering I got that BUT and forgive me because I have not been in it just yet but I am having trouble with the fact that the axle shaft (driver side) coming out of the axle tube had play up and down at the tube right where it comes out. what is there for bearings or seals there. Obvious there should not be play there. will find out when I do the job but want the parts before I do it...
Ryan
__________________
  #41 (permalink)
Old 07-05-2009, 09:52 PM
EXv10's Avatar
?????? How would it do that? If if wasn't there there would be less friction. It is to widen the support of the bearing area to be more like the earlier spread apart bearings.
  #42 (permalink)
Old 07-05-2009, 10:00 PM
EXv10's Avatar
Quote:
Ryan
There is no bearing there. There is only a light duty dust seal. The long axle ends are supported by the wheel bearing hub and the stub shaft. Don't forget you can grease your wheel bearings through the ABS hole and needle bearings also.
  #43 (permalink)
Old 07-05-2009, 10:15 PM
WA.Ranger's Avatar
Clydes' a ^^^^^
http://www.guzzle7pt3.com/nblube.php
__________________
  #44 (permalink)
Old 07-07-2009, 09:32 PM
Jim59 Jim59 is offline
Jim59 is gaining momentum as a positive member of FTE.
Quote:
you can use ball bearing for axle bearings? thanks
  #45 (permalink)
Old 07-07-2009, 09:48 PM
EXv10's Avatar
Quote:
Yes , many rear axles have ball bearings and this front hub is a unique arrangement. I would like to know what is inside the hub.
Tags
2005 , balljonts , brg , explorer , ford , labor , replacement , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
