Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2010 6.4L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2008 - 2010 6.4L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 01:42 PM
fairhaven fairhaven is offline
fairhaven is starting off with a positive reputation.
Do You Always Have To Wait 3-5 Minutes Before...
turning off the motor? If I run to the store, which takes about 10 minutes, do I need to sit in the parking lot, with the motor running, for 3-5 minutes?
  #2 (permalink)
Old 07-01-2009, 01:57 PM
R-T0r21on R-T0r21on is offline
2008 Ford F-350
R-T0r21on is starting off with a positive reputation.
No. Check your diesel supplemental guide. These trucks have a fuel cooler which cools the turbo even after shut down if/when necessary.
__________________
Job #1 F-350 SRW, 6.4 PSD, Auto, 4x4, supercab, long bed, Line-X, Vent visors, AFE cold air intake, MBRP "cool duals" exhaust, Bed locker electric retractable tonneau cover, Kenwood DNX-1820 Nav./ stereo w/ backup camera, Spartan 275 hp DOC/DPF delete tune.
  #3 (permalink)
Old 07-01-2009, 02:20 PM
ssharber's Avatar
ssharber ssharber is offline
2008 Ford F-250
ssharber is starting off with a positive reputation.
I thought the purpose of waiting 3-5 minutes was to let the turbo's spin down some, if you had just been using them pretty heavily, so the oil could cool the bearings and the bearings would not spin with no oil pressure, not because of the temperature of the fuel. Am I wrong? Just curious
__________________
Scott
'08 CC Lariat
Remote ByPass
Spartan DashDAQ
S&B Cold Air Intake
  #4 (permalink)
Old 07-01-2009, 02:32 PM
trfdfirefighter's Avatar
trfdfirefighter trfdfirefighter is offline
2008 Ford F-250
trfdfirefighter is starting off with a positive reputation.
to the original question, no you do not have to wait, but sharber if you have been working the engine/turbos hard towing or something you should let it cool for a moment just dont forget that excessive idling is not good for the dpf.
  #5 (permalink)
Old 07-01-2009, 03:27 PM
smotrs's Avatar
smotrs smotrs is offline
2008 Ford F-Super Duty
smotrs is starting off with a positive reputation.
As trfdfirefighter mentions. You need only wait the 3-5 minutes when you have been towing a large load or been running the engine really hot for considerable amounts of time. The idea being you want to give the turbos and engine a chance to cool down to normal operating temperatures.
A quick jont to the store, may not even get it up to normal operating temps, let alone higher then normal temps.
__________________
Shaun
Quote:
Originally Posted by George Bush
Wait, what did you just say? You're predicting $4 a gallon gasoline?. . . That's interesting. I hadn't heard that.
  #6 (permalink)
Old 07-01-2009, 03:29 PM
senix's Avatar
senix senix is online now
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
trfdfirefighter is right, try not to idle excessively and as long as you were not working the motor you can shut it down.
If say for example you just got off the interstate at a rest stop you would want to sit for a couple, especially if you have a load behind you.
That's about it.
Please note to get the best out of the truck use it hard and it will perform better.
__________________
2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
  #7 (permalink)
Old 07-02-2009, 07:58 PM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
SHADE TREEIN SINCE 1957
StanleyZ is gaining momentum as a positive member of FTE.
I have an after market gizmo on the 7.3 that let's me set a timer for from 1 min to a couple hours and then shut everything down and leave. When the timer runs out the truck shuts down. It's called a "Diesel Turbo Lifesaver" (DTLS). Works great at stops when towing. Don't know if they make one for this truck but I would think they would. It's a plug and play with a timer button on the dash. I found mine at a local Ford Super Duty speciality shop. Have no idea on the manufacturer.
__________________
2008 F350 DRW Lariat/ 4.30 Diff/Titan 60 Gal fuel tank/Bone stock running gear and just a little truck bling.
  #8 (permalink)
Old 07-06-2009, 01:44 AM
Randy777 Randy777 is offline
Randy777 is starting off with a positive reputation.
I have a 2004 6 liter and have a Pyro gauge on it. They say to wait until it gets to about 350 degrees before shutting down. I've found that even after climbing a hill in 110degree temps pulling my fifth-wheel that it never takes over a minute and a half to cool to 350 from over 900.
If I'm in town it will cool to 350 in about 20 seconds from 600.
__________________
2004 F250 4x4 EGR studs
EGR delete
Harpooned fuel tank
Dieselsite Coolant Filter
Isspro Gauges Coolant Temp, Oil Temp
Tranny Temp, Pyro, Boost
  #9 (permalink)
Old 07-07-2009, 11:23 PM
sbaset sbaset is offline
sbaset is starting off with a positive reputation.
Easy solution....don't turn it off...LOL. Kidding guys!
But when I did a 28 hour straight shot from Atlanta to Phoenix with a partner, I think we turned the truck off maybe 3 times total.
Tags
2008 , 64 , diesel , ford , lifesaver , liter , turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
