Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 07-04-2009, 09:56 PM
lmnr0026 lmnr0026 is offline
lmnr0026 is starting off with a positive reputation.
Yeah Dave, this has been a real headscratcher for sure. Doesn't help that this is my first time working on this stuff. LOL The only thing I can think of is that the lift pump just doesn't deliver the volume at pressure that's required.
Any tips on where to draw fuel pump relay trigger signal from?
__________________
1989 7.3L E-350 based Wheelchair Transit bus converted to Recreational Vehicle.
  #17 (permalink)
Old 07-04-2009, 10:04 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by lmnr0026 View Post
Opened the fuel line between filter and IP to see flow there, and the lift pump seems to be working OK... reaching about 5 lbs pressure after cranking it a few times. Flow rate seems OK, 1/3 pint in 10 secs looks like that was being delivered. fuel looked clean and without air.
Yeehaw!! We have ignition!!!Finally after days of mucking around, learning about the fuel system and trying to get this running, it's running again.Now to button up the engine, install the electric pump, and hit the road. Electric pump is on the pavement out the front of the vehicle for testing purposes -- wanted to know ASAP if it would work. Still not real sure what went wrong, but maybe the lift pump wasn't working under load.Thanks for all the assistance and information, in this thread and all the others! I'm now a premium member, well worth the price of admission. Hopefully I'll be in my new home in Vancouver before midnight tonight. My first full day of work is tomorrow, so it's not a moment too soon.
Sorry, I feel bad, I was the first to say IP.Though I am very happy and relieved that you are on the road.Thanks for letting us know and please let us know you are safe at your destination.Yes, I agree, Premium Membership is the cats meow! NO ADS!-Enjoyfh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #18 (permalink)
Old 07-04-2009, 10:11 PM
ARRRRG!
Sorry for the lack of formatting, I tried.... I've had a wondeful day, woke up to the smell of burnt electronics, The POS Western Digitial HD took on a new habbit, Smoking!
So I am on a PILE O CRAP M$ borrowed system.
I've ordered a drive, It'll be a few day getting here.
Sorry for the mess Micro**** has produced!
-Enjoy
fh : )_~
__________________
  #19 (permalink)
Old 07-04-2009, 10:15 PM
Go figures!
That one formatted fine... ARRG! I HATE MICKEYSOFT!
-Enjoy
fh : )_~
__________________
  #20 (permalink)
Old 07-05-2009, 01:50 AM
Amazing how slow I work. LOL Just about got 'er done. Pump is installed on the frame, plumbing done, wire run up through floor and firewall to battery. Got to put in 5A fuse and relay (trigger from FSS I think) and done. But I am too old to be up this late, not going to risk the 3 hour trip through unfamiliar mountains tonight. Work will have to wait... and since I'm buying the business, and it's fully staffed, they'll be OK without me for the morning.
At least the plumbing is done, and it's running fine. In fact it seems better than ever. I had a weird 'problem' where most injectors seemed flaky... cracking the lines didn't result in stumbling. Now I am happy to note that all lines when cracked produce a stumble, and the whole bus rocks when I hit the accelerator. New injectors last week didn't really make a big difference, but this new pump sure does! I can't wait to see how it pulls!! If it can hold speed up a 5% grade I may wet myself.
__________________
  #21 (permalink)
Old 07-05-2009, 11:09 AM
O don't do that it makes a mess that stinks after it rots a little...
Besides stopping on a grade to cleanup makes for a hard pull the rest of the way up!
Good choice, life is already to short.
-Enjoy
fh : )_~
__________________
  #22 (permalink)
Old 07-05-2009, 12:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
Trigger from the FSS or any of the ignition circuit is good.
Green stripe on a red wire over by the passenger side fender is the ignition circuit wire color.
Over at the IP, front terminal drivers side of the IP.
The timing advance and fast idle terminals have power till the engine reaches 112 degrees, then go dead.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Tags
1991 , diesel , f250 , ford , fss
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
