Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 12:57 PM
fear_nothing fear_nothing is offline
fear_nothing is starting off with a positive reputation.
Likes PARK - opposition to Drive
I've had my EX for about 4 yrs, its always been hard to put in gear from park. Normally I put a bunch of pressure on the brake and it will go into gear. Once it finally drops into gear it typical makes a small "click" noise. As in something dropped into alignment or place. Don't really think its tranny related - no too much to look at under the dash except for the cylinder that's attached to the brake.
Thoughts?
quick specs
'04 - 6.0 PSD - 4x4
  #2 (permalink)
Old 07-01-2009, 01:42 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
It shouldn't take much pressure on the brake to disable the shifter lock out solenoid. I believe there is a detent bar and roller at the column, but the detent pins in the transmission really should do the work of locking the selector in place.
Does it move freely in the other gears once it's out of park (say drive to neutral to reverse and back to drive)? It could be a voltage or solenoid problem on the brake lockout.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #3 (permalink)
Old 07-01-2009, 05:40 PM
gr8scott72 gr8scott72 is offline
gr8scott72 is gaining momentum as a positive member of FTE.
Quote:
Thoughts?
quick specs
'04 - 6.0 PSD - 4x4
Parking on a hill?
__________________
Scott
2000 Excursion XLT 4x4 V10 4.30, Powerslot slotted rotors w/ Hawk SuperDuty pads up front, Hawk SuperDuty pads on the rear stock rotors, Roadmaster Active Suspension, Optima Red Top Battery, backup camera, Tom Tom XL100 GPS
  #4 (permalink)
Old 07-02-2009, 12:28 PM
excursionism excursionism is offline
excursionism is starting off with a positive reputation.
we just replaced the brake on-off switch/interlock because of a short, the cylinder you are seeing under the dash.
instead of applying "a bunch of pressure" to the brake pedal, try applying pressure to the left side of the brake pedal.
alternatively, turn key to run position, just before engaging the starter, and place transmission in neutral. start the x with foot on the brake and after x starts place lever in reverse/drive.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
