Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 12:26 PM
sah27 sah27 is offline
sah27 is starting off with a positive reputation.
Airbag Light
The Air Bag light on the instrument panel is remaining illuminated on my '99 Ford F-150. The manual says to have the system serviced. Does anyone know what this entails? I'm not sure if this is related or not, but i have also noticed that my radio appears to be shorting out as the reception (radio or CD) is broken or intermittant at times.
  #2 (permalink)
Old 07-01-2009, 02:53 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KY KR lover
2002 Ford F-150
KingRanchMan02 is gaining momentum as a positive member of FTE. KingRanchMan02 is gaining momentum as a positive member of FTE.
Welcome to FTE sah27! Does the light flash on and off in a code before it stays illuminated? If so, count the number of flashes. There should be a pause after the first series of flashes and then the second series of flashes giving you a two digit code. Good luck!
__________________
John, aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege, 5.4L 3.55 LS, 4x2, Diablosport Predator Programmer, K&N filter.
FTE Ride of The Week, 4/20/09 !!!
`08 Mercury Sable Premier, 3.5L Duratec, 6 speed auto
  #3 (permalink)
Old 07-01-2009, 03:10 PM
Re: Airbag
Thanks for the info KingRanchMan02! The code that is coming up is 72. Any idea what this code indicates?
  #4 (permalink)
Old 07-01-2009, 03:54 PM
KY KR lover
2002 Ford F-150
More than likely is is a code 27. This is the code for a burn out light in the passenger air bag cut off switch. Search "air bag code 27" and you should find a thread with a Radio Shack bulb or LED to replace it with. Good luck!
__________________
  #5 (permalink)
Old 07-02-2009, 07:59 AM
Thanks again
You're absolutely right again KingRanchMan02, the code was actually "27". Thanks agin for your help!
  #6 (permalink)
Old 07-02-2009, 10:10 AM
dragon wagon dragon wagon is offline
dragon wagon is starting off with a positive reputation.
Look it up on You Tube!!! Some guy made a video on how to fix code 27 airbag light. You can't get any better than that. I fixed mine in about an hour for under $5.00 and that includes the trip to Radio shack.
Chris
  #7 (permalink)
Old 07-08-2009, 10:41 AM
Fixed
Watched the you tube video and fixed the problem in less than 30 minutes. Thanks again dragonwagon and KingRanchMan02. This website is an excellent resource for Ford truck owners!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
